Question about Acer Aspire L100 PC Desktop
Matshita DVD-RAM driver won't load on Acer Aspire L100 (Vista)
I have a Matshita DVD-RAM UJ-85JS drive on my Acer Aspire L100 running Vista. Device Manager is giving me the exclamation mark saying that something is wrong with the device. Turns out it is getting an error message 39 (can't load the driver--may be corrupted or missing).
I've tried to update the driver (but Vista thinks it has the most current driver). I've unistalled/reinstalled, but it still doesn't work. I've also been the Panasonic/Matshita site, but the pages won't even render tonight.... (argh!)
Anybody know of a fix?
Re: Matshita DVD-RAM driver won't load on Acer Aspire...
Angela 1116 here:
go to:
it is where i found info on how to finally fix it. also-- after you do it, take battery out for 10 seconds to help it reset if it wants you to restart more than once.
the toshiba support walked me thru it and gave me this page.
Posted on May 31, 2008
Go to start -> execute, type regedit and click OK.
Search for : HKEY_LOCAL_MACHINE/System/Currentcontrolset/Control/Class/
Click with right mouse button on key: {4d36e965-e325-11ce-bfc1-08002be10318} and choose for Export. Choose a directory and name to save the backup key
Remove in the right window: UpperFilters en LowerFilters
Restart your PC again. It will install you DVD/CD drive again.
If it won't work, you can always install your backup key by double clicking it. Good luck, it worked for me
Posted on May 13, 2008
  • 209 Answers
You need to repair this by using the vista installation cd just press repair the driver will be reinstalled by this oerating system
Posted on Jan 21, 2008
0 characters
3 Points
MATSHITA DVD-RAM UJ-820S not reading dics
install drivers, download from internet and see if that helped
Apr 27, 2009 | PC Desktops
Computer problem
Get some other software like Nero. It is mach better than any Windows Software. Especially if you are using VISTA>
Feb 20, 2009 | Acer Aspire L100 PC Desktop
Acer aspire l100 dvd problem
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
Feb 14, 2009 | Acer Aspire L100 PC Desktop
Code 28 error for matshita dvd-ram uj-852 ata device
Please go to the device manager by typing and entering devmgmt.msc in run option.
click the plus sign given before dvd cr rom drive and uninstall the drive coming.
then clisck the plus sign of ide ATA/ATAPI controllers and the uninstall the secondary IDE channels.
Retart the machine twice.
If the also the issue is not resoved then you will have to reload the OS again.
Jan 31, 2009 | PC Desktops
Cant burn files to Matshita dvd ram uj 85js
i need to now the error code/message?
i had a similar problem with my Matshita dvd drive by deleting a registry entry that had become corrupted i was able to write. before that all i could do was read discs.
try this link it could help you out.
i cannot remeber the precise location in the registry, but it has to do with the upper or lower filters.
Jan 28, 2009 | Acer Aspire L100 PC Desktop
Anyone know if the Matshita UJ-861h ATA drive will handle dual layer dvds?
Here is what the HP site quoted as specs:
Optics: Matshita DVD-RAM Uj-861H (CD-ROM / -R/-RW - 24x/24x/24x,
DVD-ROM / ± R / ± RW / ± R DL - 8x/8x/6x/4x)
Looks like + and - R Dual Layer is a go!
Jan 17, 2009 | PC Desktops
My dvd drive(Matshita DVD-RAM UJ-852) is locked on region 1. How do I unlock it? andrew
download software like region free dvd player enjoy, or for changing the dvd region code go to device manager select the dvd right click on it go to properties, go to region code change it, but becautious you can change the region code for only five times
Nov 09, 2008 | PC Desktops
I have a dvd drive (matshita dvd-ram uj-85os ATA device). whenever i instal itunes, for some reason, my dvd in my laptop does not want to work. when i uninstall it, the dvd works. can't seem to figure...
hai! if DVD drive works when you are using some ither disc! it can works mean! your itunes driver disc have some cracks so it can be works! the better think is you download from the internet! then you install!
Here some of iphone driver for you! you click the link and download! - 30k - - - 84k -
Sep 15, 2008 | PC Desktops
Need driver for dvd-ram uj-8425
genraly dvd ram doesnt need drivers they are plug and play some how if it is not working ....u can ask the vendor from where uv purchased or u can use this link
Aug 17, 2008 | PC Desktops
My matshita uj-860s disc drive has stopped working
In my case, MATSHITA DVD-RAM UJ-860S did not want to write CD-R,-RW Verbatim using software NERO 8, but is easy to write their own software windows XP.
in the Log file was as follows:
Could not perform start of Disc-at-once
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Power calibration error
Invalid field in parameter
Change in method of recording NERO 8 Burning mode: DAO (Disc-at-once) at Burning mode: TAO (Track-At-Once) all have established!
Simply drive MATSHITA was UNSUPPORTED software producers to write disks.
Updating the software to burn CDs, as is windows XP supports the recording and includes drivers for the drive! :)
Apr 17, 2008 | PC Desktops
Acer Aspire L100 PC Desktop Logo
260 people viewed this question
Top Acer PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you an Acer PC Desktop Expert? Answer questions, earn points and help others
