Question about SanDisk Sansa Clip MP3 Player
Battery It wont charge when i plug it in the USB. After charging it continues to say low battery.
  • ambere Jan 21, 2008
    it will charge for 30 sec and then think its connecting to the computer
  • 3 Answers
I called sandisk. You have to have service pack 2 on your windows XP and you have to have Windows Media Player version 10 or 11. One one of my laptops I had version 9 and it wouldn't work, I changed laptops and it works just fine.
Posted on Jan 26, 2008
Why wont my zeepad turn on
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
May 10, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Cobra Mirco Talk CXT 195
pls check usb cable , replace with new gud quality short length usb cable n try to connect the same in back side USB port not front side ..
Jan 15, 2014 | Cobra Radio Communications
Emerson emp287c-4 wont charge with usb
Having same issue, battery will not charge. Can't even use it unless its plugged into my computer the whole time. Followed the charging instructions, "turn power switch on and then use the usb cord provided to plug the device into the computer." I do so and it reads that it is charging, however the bar never goes to the green charge symbol. It said to not let it charge past 8 hours so I always unplug it before that. Even tried the recommended 3-5 hours and still I turn it on and it says right away battery low.
Dec 26, 2012 | Emerson Televison & Video
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
I shut down the computer while charging my mp3
Try plugging in the USB connection again. If that doesn't work, unplug it and then press and hold the on button for ten seconds.
May 06, 2010 | SanDisk Sansa e250 MP3 Player
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
Cect i9 wont charge battery is fine
the issue is with the wall usb ac adapter just replace it (with a better quality one) and it should work, you can also charge the phone using your computer. Well... this fix worked for me.
Dec 10, 2008 | Dual Electronics CECT P168 Cellular Phone
Phone shut off
Plug it into your walloutlet usb charger rather then the one connected to your pc. once your battery is so low it wont even have enough juice to show the charge battery screen if your chargeing through the low voltage pc active sync cable.
Feb 11, 2008 | Motorola Mobility Moto Q
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Mintek 8" TFT portable dvd player MDP1810
DO NOT continue to try to charge that battery. The company recalled those batteries because they explode or start on fire. Do a google search of "mintek" and you can read about the recall.
Jan 10, 2008 | Mintek MDP-1770 Portable DVD Player
SanDisk Sansa Clip MP3 Player Logo
63 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
