Question about Toshiba Satellite A105 Notebook
Toshiba a105 I've been having trouble with this laptop since I got it.I had to replace the AC adapter 3 times. Each time the adapter burned up. I finally bought an aftermarket adapter that has seemed to have lasted. My current problem is that the Laptop's screen started flickering. I figured it might have been some kind of overheating problems so I used a can of Air to blow out the CPU vent. I also took out the Memory module to check the contacts. When I put module back I failed to install it fully. When I went to power up the power light came on and immediatly went out. I thought maybe the battery was dead so I plugged in the ac adapter. The ac power and battery light wouldn't come on at all. I finally realized the memory module wasn't in fully. Now the ac power and battery lights come on but the Laptop won't power up at all. Please Help thanks
  • temoteo Jan 31, 2008
    I, too, have gone through 3 ac adapters in the last 2 months. What was the solution? Just buy a fourth adapter?
    Genius:
  • 1,067 Answers
Bad mother bord replace that bad power transiters on it not doing well and cpu getting hot may need new greese
Posted on Jan 21, 2008
Battery/Ac adapter issues for Sony VAIO Model
So I gather the laptop does not run when the battery is in and the AC adapter is not connected? Laptop batteries tend to ware down over time and will need to be replaced as they end up not being able to hold any charge. Look online for a new replacement of the battery under the model number of your laptop
Aug 13, 2013 | Sony VAIO PCG-K33 Notebook
I have a HP laptop that won't power up. I put in a new battery, and bought a new AC adapter. Now lights nothing. It was running than just quick and I haven't been able to get it to come back o
Hi There,
If you've got a multimeter - test your AC adapter to see if it is outputting the correct voltage for your laptop. If it is, Then you've got an HP boat anchor. Unfortunately HP laptops are known for their overheating issues, and if this is the case, a lawsuit filed against said manufacturer means you may be able to be compensated for your loss.
Jul 18, 2012 | Computers & Internet
Why my pc presario x1000 power and lamp lights blink and the batteries can not be on my pc
I fix these laptops as a side business and sell refurbished ones on ebay...I've seen the problem you describe but I'd need to know more about how fast they are blinking, etc. When all the lights flash about 2-3 times per second, I've found it to be a motherboard issue normally caused by a faulty power jack. That can be fixed but it means disassembling the complete laptop down to the motherboard and either re-soldering or replacing the jack. If you have access to a charged battery, disconnect the AC adapter and try to get it to boot cleanly from the battery. This will tell you if the problem is at the jack or someplace else. Post your results and we'll go from here.
Jun 09, 2012 | Compaq Presario X1000 Notebook
I have a hp compaq 6720s, an pver time i have noticed that the ac adapter (the part that plugs in to my laptop) has been getting very hot at times, even so that i have burned my finger once when I had
If the DC jack in the laptop is getting to hot it indicates bad connections on the motherboard where the jack is seated, it will need to be dismantled and inspected, plus the power supply adapter checked for proper plug fitting.
May 27, 2012 | HP Compaq 6720s PC Notebook
Hp dv 2500 mb-ct:P74511B2DV33T2 p/n GS846UA#ABA s/n 2CE7380QWD Laptop wont boot Lightning led flashes three times with or with out battery. Have done hard reset. Battery wont charge,blue power input...
My HP flashes 3 times when my battery is dead. Because of this I'm guessing that the AC Adapter is not working properly because it should turn on even with the battery out as long as it's plugged in. Many power adapters have a light on the actual converter box, you want to take a look for that light. If it is on, there is a problem with the cable and/or the connections between that box and the computer. If it is off, try another outlet. If you've done all this troubleshooting I would probably recommend getting a replacement AC Adapter. They are specific to the computer so make sure you purchase the correct one. Last time I replaced one the cheapest I found one (Dell Inspiron 1525) was @ Amazon.com
May 05, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
Power button inop at times & Power connection loose
Hi kimicob. From what you have described, it sounds like your AC adapter (power cord) is bad. This is a common problem with laptops. I have had to replace mine 3 times! Depending on what type of laptop you have, you can probably find a generic power cord online for less than $30. Or you can go to the laptop company's website and buy one from them, but it will cost much more, if they still carry it. You can try newegg.com or tigerdirect.com or just do a google search for AC adapter and the model of your laptop. Best of luck!
Aug 15, 2009 | Computers & Internet
Burning smell on my laptop
Unless you have the ability to to replace the plug connector part yourself, you will have to take it in to a shop who can do that kind of fine soldering for you. If nothing else is damaged, it should be ok with replacing just that burnt out part.
Jul 12, 2008 | ASUS Computers & Internet
Toshiba Satellite A105 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
