Question about Honeywell Programmable Thermostat Heater
Honeywell VisionPro USER SETUP CODES OR INSTALLER CODE FOR TEMP RESTRICTION
Model TH8000: I can not adjust the heat above 68 F. I can get into the user setup codes but I dont know which one is for the temp max minimum setting there are ,13 different codes: 120, 130, 140,150,160, 320, 330,500,510, 520,540, 640, 670.
To enter the you press the SYSTEM button (HEAT, OFF, COOL) Then press the center button at the bottom ( no label ), for 10 seconds to enter the setup mode. Is this the correct place to find what I am looking for ?
You need to get into the installer setup. Download the installer manual from Honeywell or an on-line vendor and it has the installer codes to alter the maximum heat setting. Press the system button and then buttons 2 & 4 at the same time for 5 sec to enter the installer mode. I believe the code is 0600 and then you enter the max temp for heat setting. Press done and your done!. Try this link for the installers manual http://www.alpinehomeair.com/related/Honeywell_VisionPro_8000_%20Install_%20Instructions.pdf
Posted on Feb 12, 2008
HAD A SIMILIAR PROBLEM AND HONEYWELL WOULD GIVE ME NO HELP. YOUR SOLUTION TO THE CODE WAS RIGHT ON THE MONEY!
THANK YOU
Posted on Jun 18, 2008
2 Suggested Answers
SOURCE: Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Posted on Jan 31, 2009
Even when system is turned off the fan runs. put batteries in as there were none, no change. is thermostat shot?this an ac/furnace unit with vision pro th8000 series thermostat
The issue is probably not the thermostat. The thermostat is a series of switches that turn on and off in respect to the temperature. Since it takes batteries and installing those made no difference there is a chance that a relay is stuck in the furnace or the thermostat. I have attached the testing and installation guide for you to look at. Honeywell VisionPRO TH8000 Series Installation Manual Installer System Test
Mar 05, 2018 | Heating & Cooling
I have the VisionPro TH8000 home touchscreen programmable thermost, which is 3 years old, and was installed with a new heating and air system. It has worked flawlessly up until this week. All of the...
http://www.completeheating.ca/manuals/VisionPro%208000.pdf
Try the screen button and clean your screen in the given time.
also try honeywell.com/yourhome and use the contact us. They will try to walk you through and fix the problem as an ac company will usually just try to sell you another. These are not cheap stats I use one myself, I've have mine for years. I know it isn't much but hope this puts you in the right direction.
May 15, 2011 | Honeywell Electronic Programmable...
Honeywell T2060 UtilityPro Demand Control Thermostat
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 16, 2010 | Honeywell Electronic Programmable...
I have a TH8000 Vision Pro. It is controling a
Whats' so hard is the Honeywell thermostat has a built in 1@ differential. It is not adjustable.
You might ask your installer about a time delay relay installed in the furnace to break the thermostat heat wire (usually white wire).
Most time delay relays are 90 seconds. But that might be enough to reduce the furnace cycling.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Th8000 does not match another thermometer inside home
Is the thermostat mounted near a lamp or other heat source?
Is the wall warm from ducts in the wall or a refrigerator on the other side?
The thermostats are usually pretty accurate. Most times I find some other influence on the thermostat causes the problem.
The Honeywell 8000 series also has a feature accessed through the installer setup menu, that will allow the temp display to be changed + or - 8 or 9 degrees.
Check the manual or Honeywell's website for a .pdf if you need it.
Hope this helps.
Matt
Jan 11, 2009 | Honeywell Electronic Programmable...
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Honeywell VisionPro TH8000 touch screen will not allow changes to the schedule. Screen is unlocked and not in cleaning mode
In the set up mode are you sure the lock was not turned on. The set up mode has a different book for the installer. Do you have the book if not check with Honeywell or let me know.
Sep 27, 2008 | Heating & Cooling
Heating & Cooling Logo
4,327 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
