Question about Philips PET708
Second screen does not work
While plugged in and in multi mode, the second screen only displays a no signal message. Should I return it, or am I missing something?
  • Anonymous Aug 22, 2008
    I have the same "No Signal" message on my second screen but I have soundfrom the second screen.  I have triple checked that all the cables are in correctly with no luck.  Is there just a defect on the second screen or is there something that needs to be "unlocked" on the master dvd that I'm not aware of?
  • 476 Answers
Make sure you have the both lead from the main unit to the second screen plugged in (Power and video lead - 3.5mm jack to red/white/yellow phono)
Also make sure the jack is plugged into the A/V OUT socket of the main unit and NOT the A/V IN.
Posted on Feb 22, 2008
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
Tip
Sony DVP-NS725P Region free code.
This region free hack also works for the DVP-NS725P using the original remote control. If the first one fail try the second one, it works like a charm.
Thanks a lot....
SONY DVP-NS300, DVP-NS305, DVP-NS400D, DVP-NS700, DVP-S330, DVP-S335, DVP-S360, DVP-S336, DVP-S525D, DVP-S530D, DVP-S535D, DVP-S536D, DVP-S725D, DVP-S735D
Multi-Region:
Turn On the unit with the remote controller
Wait until "no disc" appears in the unit's display
Press Pause, 3, 1, 4, 1, 5, 9
The word "CODE" should appear in the display
Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
Put the player into Standby mode
Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
Press Audio and Return for auto-switching On
Press Angle and Return for MacroVision On
Press Subtitle and Return for MacroVision Off
on Mar 07, 2010 | Televison & Video
It is stuck on video mode and there is a message on the screen stating unusable signal. How do I return it to TV?
Hello
Highlight Exit and press MENU
Press 0 on the remote
Press CLEAR. The on-screen displays are cleared from the screen and you
return to TV viewing
Ok
Jun 25, 2011 | RCA F25441 25" TV
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Mar 31, 2011 | Alpine CDA-9827 CD Player
Upon start up there is no video for GUN in Win 7. I have tried using the compatibility mode and it doesnt seem to work either.
Are you using multi-display? I disconnected my second monitor and the video came up. It may just be an issue with Gun and Win 7. Perhaps trying to stretch the screen to the second monitor.
May 11, 2010 | Activision GUN for Windows
Cannot connect acer extensa 5220 laptop to hd tv via aga
Hold down Fn and tap F5, you may have to tap F5 a couple of times to get it to switch screens.
Regards.
Feb 19, 2010 | Acer Computers & Internet
Can't receive faxes
The problem is that some one has changed the answering method of the fax machine it writes "F/T" because the fax machine is set to FAX/TEL mode. So to make your fax machine to be on fax mode and on the screen to write " FAX " you need to press the button mode which is located under the screen exactly under the message " F/T " after you will press the button " mode " on the screen it will appear the current mode that the fax machine is set to, so you will need to press the " mode " button until on the screen will appear the message " FAX " when the message " FAX " will appear on the screen do not touch any button on the fax machine and after 2 second on the screen will return to the date and time display and again it will display on your fax machine
" FAX " and it will not display " F/T "
Jul 10, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Philips PET708 Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
