Question about RCA T19408 19 in. TV/VCR Combo
Resetting TV Color Settings.
I've recently had a child ruin my TV color and there is no reset feature. Would anyone be able to tell me the default settings or even ones they have found that work better? Because as of now I have a green tint to mine, and when I move the tint a little further to the red side everyones face looks like an apple. I have tried contacting RCA but they were no help at all. I understand it could be a bit time consuming counting each line from left to right, but thanks to whomever does it.
  • InFiNiTe7924 Jan 21, 2008
    There are around 30 or so notches, I have tried placing them all in the middle with no luck.
I need the setting of internal colour for eg RR set as 50
Posted on Dec 08, 2009
    Problem Solver:
  • 5 Answers
Generally 50 is the middle setting. try setting the color bars all to 50 and see what happens.
Bill
Posted on Jan 21, 2008
Why does my Westinghouse 32" flatscreenTV shows fuzzy psychedelic colors
Have you tried resetting the TV's settings to the factory default?
You should be able to do that within the settings menu on the TV.
May 01, 2014 | Westinghouse LTV32W6HD 32 in. LCD...
Have a hl61a750a1fxzc(model) tv, tv is about 5 years old. Tv has a greenish picture tint... Looking at http://ww2.justanswer.com/uploads/TVTech1/2010-07-02_101408_SMPTE_Color_bar.jpg top 7 colors on my tv...
please do this test: God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Aug 01, 2013 | Samsung Hl61a750 61" LED Powered DLP HDTV
My Toshiba tv has no picture or sound, it only tells me that the door is open.
please do the next test.God bless you
Jul 31, 2013 | Televison & Video
Reset color color is not right to much blue
You may have to go through settings and do resetting if necessary to factory default and try.
Aug 19, 2012 | Westinghouse W4207 42 in. HD-Ready LCD TV
How do I reset. I have pressed a button and I now have a grid, which I dont want. I only use the tulip sign and the x1 Help. Many thanks.
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD960 IS.
Resetting Settings to Their Default Values - PowerShot SD960 IS. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd960menupress.jpg 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd970reset.jpg 4. Select [OK] and press funcseticon.gif. sd970resetall.jpg
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language], [Video System], and [Time Zone] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • The image registered as [Start-up Image]
Aug 02, 2010 | Canon IXUS 960 IS Digital Camera
My canon ixus70 will not take photos,I can view past photos but it will not show image on screen or record digital image ,if I take a shot all I get is a black nothing. Janis jvdzelde@bigpond.com
Solution: Procedure for resetting the camera to its default settings PowerShot SD750 and SD1000.
Resetting Settings to Their Default Values - PowerShot SD750 and SD1000. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd750resetscreen.gif 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd750resetscreen.gif 4. Select [OK] and press funcseticon.gif.
    • Shooting mode
    • The [Date/Time], [Language] and [Video System] options in the setup_icon.gif(Set up) menu
    • Newly added My Camera settings
Jul 28, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Neon blue hurts my eyes
You might wanna reset your monitor's settings to default, just play with your monitor's options untill you find the reset to default option. If resetting the monitor's settings doesnt work, then try resetting your video card's settings. right click the desktop and open your video card's control panel, then look for the reset to default options, especially on the color settings, wherever they are (control panels for graphic cards vary by vendor ie ATI/Nvidia, and/or by the control panel's version)
Jun 11, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
My scanned color photos
  1. Check the automatic brightness and color settings by doing the following:
  2. Click Settings , click Scan Settings and Preferences , then click Preferences .
  3. Enable or disable (depending on their current state) the Automatically adjust exposure and/or Automatically adjust color settings.
  4. Click OK .
  5. Expand the scan preview by clicking the arrow on the right, and then adjust the Color settings prior to performing a final scan.
  6. Sometimes the scan will pick up reflected colors, try rotating the original 90 degrees and then scan again.
  7. All models except the PSC 1100 and 1200: If the scan still is not right, try resetting the all-in-one back to the factory default settings. Follow these steps to reset the defaults:
  8. Press Setup or Menu depending on your model.
  9. Press the Right Arrow or the Down Arrow until Maintenance or Tools appears in the Display, and then press Enter .
  10. Press the Right Arrow or the Down Arrow until Restore Factory Defaults appears in the Display, and then press Enter .
  11. Reset the all-in-one by unplugging the power cord and then plugging it back in. This will force the all-in-one to recalibrate
Good Luck
Aug 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Phaser 7300N
I would say this will have to be done to stop that.
But you will have to basically set up the printer as if you were newly installing it.
Resetting the NVRAM will reset all printer values including network, printer setup, job defaults, and color calibrations.
  1. Press the Down arrow key and scroll to Support.
  2. Press the OK key.
  3. Press the Down arrow key and scroll to Service Tools Menu.
  4. Press the OK key.
  5. Reset NVRAM will be displayed.
  6. Press the OK key.
  7. Reset NVRAM and Reset Printer NOW will be displayed.
  8. Press the OK key to reset all the settings to default.
Nov 29, 2007 | Xerox Phaser 7700 Laser Printer
Picture black and white , no color
try resetting the tv back to factory settings under within the tv's menu setting you should find a setting to reset the tv, most likely all the color and contract settings may have been tunred down,
Sep 08, 2007 | Sony KP-61V90 61" Rear Projection...
RCA T19408 19 in. TV/VCR Combo Logo
1,991 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
