Question about Hotpoint NVL333EY Electric Dryer
HELP! Motor is working but drum wont turn. Belt is fine... what else can it be?
  • 770 Answers
Well the belt is ok?? is the idler pulley ok it keeps the tension on the belt so the drum turns also the belt maybe slipping check those items and let me know
Posted on Jan 21, 2008
3 Suggested Answers
  • 46 Answers
SOURCE: drum will not turn?
the motor will most likely be ok, its the capacitor on the motor that normally blows,( the white/grey cylinder with 2/4 wires coming off it, about 3 inches long bolted to the motor its self. can be purchased separtely in eletronic spares shops. all u need is the (uF) number on the original part.
Posted on Feb 07, 2008
  • 640 Answers
SOURCE: drum wont turn
yes the start whinding shot,,,replace motor..
Posted on Jan 25, 2009
Drum wont turn but the moter does
Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have whirlpool duet wed9200sq. The dryer seems to be working fine other than the drum will not turn. It heats fine and the drum will turn by hand, the belt is fine, no warning codes or other problems.
The drum and belt may be fine but the motor may not be. Since you seem to have access to the drum and belt, you can check to see whether the motor starts. Also check to see whether the belt and tensioner device are working OK
Sep 11, 2012 | Whirlpool Dryers
Hi my hotpoint dryer wont turn please help
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to turn.
Apr 25, 2012 | Washing Machines
My whirlpool dryer front loading wont turn the drum i change the control board but still wont work .
did you check the belt to see if it's broke,the belt raps around the drum and the motor,when the motor turns on and spins the belt spins the drum.
Mar 28, 2011 | Whirlpool Duet Front Loading Dryer Rack...
Washer won't spin, motor sounds like its working, belt is fine...what do I check or do?
The belt may look fine, but if the motor is spinning, then the belt isn't transferring the motion to the drum.
First, make sure you can turn the drum by hand. Turn off the power. Reach inside the drum, grab the opposite sides and turn. If it moves more than a few inches, then it isn't the drum that's stuck. Possibly the belt tensioner has slackened and needs to be adjusted.
Jun 25, 2009 | GE WBSR3140DW Top Load Washer
Drum wont turn
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Zanussi washing machine drum will not go round at all
The bearing may have siezed or you have something jammed between the drum and outercasing
Mar 23, 2008 | Washing Machines
The washer works fine aparts from the drum wont turn at all.
there is a motor speed control board in the back of the washer. if your facing the back of the washer its on the bottom left side. there is a fuse on that board that will stop the motor from running
Nov 22, 2007 | Hotpoint First Edition FEW10P Front Load...
Hotpoint NVL333EY Electric Dryer Logo
76 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
