Question about Ovens
F0 Error code
Several hours after my wife wiped down the front of the oven it started beeping and I saw error code F0 and the key pad was non responsive so I droped the breaker for a half hour to reset it and tryed again, The same thing happened eratic beeping and the key pad would work then not work. Thaks for any help.
Joe
  • 2 more comments
  • joehotwrench Jan 21, 2008
    My model is a GE Electric convection Built in oven Model # JTP18W
    To be honest I knew it was either the control or the key pad both each costing well over $160.00 & I was hoping you could direct me to the corect one. I have 120v @L1-N & Com to N as shown in the Ovens tech data sheet. After I'v disconnected the ribbon and reconnected it the touch pad Clear/off and all others do not work. so Im still looking for the problem. ERC? or touch Pad?
    Everthing points to the ERC But like you I think it is the key pad due to the fact that is what my wife cleaned and I bet theres a stuck key.
    You know thats where my problem is, All she did is the normal weekly wipe down, Is the key pad that fragel? I just wish there was a direct test to make sure? $160.00 is a $160.00 anyway you shake it.
    Guru:
  • 1,894 Answers
Your model number please?
Posted on Jan 21, 2008
  • 6 more comments
  • dewan nafees ahmed Jan 21, 2008
    F0
    Function key stuck
    Replace touch pad or clock assembly (also called the ERC)
    source link has been mentioned
    i mentioned it for ADMIRAL but if yours is of different make you please clikc this link.
    there is a list of manufacutrers with their error codes.
    you can verify it from here... this is the link ....
    F0 - F1 - F7
    Stuck keypad may mean relay is turned on.
    Determine if problem is with the Key Panel or Control by:
    1. Pushing CLEAR/OFF pad.
    2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
    If code recurs, problem is in the control. Replace control.
    If code does not recur, problem is with the Key Panel. here is the one you asked for
    that link has all the codes for many types of GE ovens..
    please have a look
    GE
    Gas or Built In Oven Fault Codes
    F0 or F1
    Failed transistor in control
    If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
    GE
    XL44 Self Clean Oven Fault Codes
    F0 - F1 - F7
    GE
    "New '99" Range/Stove/Oven Fault Codes
    F0 or F7
    Shorted Clear/Off Key due to membrane switch, control or connector
    Shorted key panel membrane switch; Check Electronic Range Control (ERC)
    GE
    F0 and F1
    Failed Thermistor Control
    Replace Electronic Range Control (ERC)
    this is for all kinds of GE ovens..
    thank you
    hey obviously it must be the key panel.. what is your doubt in this?
    come on brother.. it must be the keypanel.. dont know what she did in it??
    from next time you clean it yourself.. dont take risk like this..
    direct test? i dont know if there is any test like that....
    if you want to do that you will have to call some tech who can bring a spare of that panel any make sure its the probelm..
    wat s tat 160$ you shake it??
Dacor model ersd30 how do i fix an F0 error code that also blinks F1 and beeps
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Feb 07, 2011 | Dacor Epicure EO127 Stainless Steel Dual...
What does an error message "F0" mean for kenmore model 911.41185991?
for a maytag the F0 code means a function key is stuck, and recommends changing out the touch pad, or touch pad and oven control assembly if one unit. google your model number for error codes.
Jun 21, 2010 | Ovens
FO error code
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
May 06, 2010 | Magic Chef 9122 Gas Single Oven
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Jun 20, 2009 | GE JKS05 Electric Single Oven
F0 error code on ge profile oven
Could be a stuck keypad. Try pressing all pads at random several times each to clear it.
If that does not work the ERC(clock) must be replaced.
May 26, 2009 | GE Profile JTP18 Electric Single Oven
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Sep 21, 2008 | GE Profile JTP56 Electric Double Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Jun 13, 2008 | Kenmore 47732 / 47734 / 47739 Electric...
F0 error - My GE Over displays an F0 error & constantly beeps
Appu, the F0 error for this built in means there is a shorted or stuck off key. Sometimes this can be resolved by removing the keypad ribbon cable from the board and cleaning the ends with an eraser. If that doesn't work, you want to find out whether its the board or keypad by ohming the ribbon cable, 3 to 4, probes on the conductor side...should read 125 to 1750 ohms while pressing the off key. Catriver..post back.
Apr 29, 2007 | GE Profile JK915 Electric Single Oven
Ovens Logo
597 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
