Question about Archos 605 WiFi Digital Media Player
No longer a tv picture to record on my 605 wifi passthrough device
For some reason i no longer have my tv showing on my archos device even though passthrough must be working as i have a picture with sound on my television?
  • superdave73 Jan 21, 2008
    I appear to have the same problem.
    With the DVR station powered off (or the 605 isn't connected) I get sound and picture fine.
    When the 605 is connected I can see the Archos menus on my TV, which is fine.
    When I'm in the Recorder I can hear audio but I can't see video. Any attempt to record fails.
    I have also found that many of the videos that I could play previously are no longer working.
    Firmware 1.7.13
Have been onto technical support today with video recording problems and they have suggested that 1.7.13 may not be the best of firmware platforms, and that i install 1.7.06. Might be worth checking with them to see if you get similar advice.
Posted on Jan 28, 2008
6ya staff
SOURCE:
My archos 604 won't play on my television.
Hi,when you connect it to TV,I believe you switch to AV mode on TV to allow signal to be shown on TV,do you ??.
If you did it but no video ,than make sure your AV cable should go all the way down on the plug on Archos.it is a fancy plug sometimes stays out half way
kazim
Jul 15, 2009 | Archos 604 WiFi Digital Media Player
Dvd without coaxial, old tv without RCA, passthrough VCR died
http://www.ellies.co.za/v2/index.php?id=492
@ tihis link above you can see it. It takes the av SIgnal Your Sound and picture and convert it RF making it possible for your tv to tune it, its just like tunning into a station. I do sell these for R199 South African Rand excluding postage
Thank you for using FIX YA
Jan 04, 2009 | Televison & Video
Archos 604 (not WiFi) connection to TV without the DVR station
HI, bought the following off ebay and they worked just fine. I to thought that the socket on the right side was audio only. Can't get a picture via my DVR (may be a fault) however this item works great.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=370172642094
Jun 06, 2008 | Archos 604 WiFi Digital Media Player
Archos 405
Hi fiona
I had the same problem as the archos web site is not the easiest to navigate.Have you actualy registered the product yet ?if so once logged in add your device as a product,on my products click on the picture of the 405 and that will take you to the screen for downloading archoslink (software to install the tv guide) and to the subscription page for down loading the tv guide.
How ever i have done all this and although i can download the guide i cannot sync it to my 405 so still unable to record off tv....Email gone to archos so fingers crossed....
Apr 27, 2008 | Archos 405 Digital Media Player
Fix a Tripp-Lite BCPRO1050 UPS
Hello there Eloss
Yep, you need if I am not fail, to changed every 2 years, depending the use.
good luck
Apr 11, 2008 | Computers & Internet
PC no longer recognizes my Archos 605
in the archos....select SYSTEM....change windows media player to PC Hard Drive and this worked for me
Mar 24, 2008 | Archos 605 WiFi Digital Media Player
Archos 504 dvr shuts down when I plug it into the tv and there is no sound.
The same thing happens to me. I've noticed that it is on the dvds and vhs recordings (ie, copy protected) that this happens. The other files (downloaded from internet, tv, etc) play fine. I think it has something to do with copy-protection that allows files to be saved to device, but not transmitted out. This allows you to save and view your commercial recordings on the Archos, but not let the program to be sent to a recording device such as a dvd recorder.
Jan 25, 2008 | Archos 504 500870 Digital Media Player
Archos 700
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
Oct 09, 2007 | Archos AV700 Digital Media Player
Display shows very very faint image. Can't turn device off.
Sounds as though your back light for the LCD may have gone. It is not a job the DIY repairer can easily complete therefor you should return it to Archos or a certified repair center for an estimate. If it is in warranty Archos MAY cover it, though if they deem it has been dropped will likely charge you.
May 24, 2007 | Archos AV 700 160-Hours Video Recorder
Archos 605 WiFi Digital Media Player Logo
56 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
