Question about Technics SA-DA8 Receiver
Sa-da8 overload and off
Hi, i have a Sa-Da8 and when i listen to music more than 45%, overload came on and the amp came off. No wire are touching, nothing visual to. Do you have suggestion?????thanks
  • Djteac2 Jan 22, 2008
    I have no eq setttings in that amp. What else can i do?
  • Edward Yoo
    Edward Yoo Feb 14, 2008
    I had the exact same problem with my unit.
    upon careful inspection after unit was disassembed found one of the zener diode was burnt or totally shorted out.
    I'm an electronics technician, but for you, I recommend to have that serviced at on of the panasonic service centers..
  • 979 Answers
Be sure that the EQ settings aren't accidentally putting you over the top as far as demand is concerned. Bass-heavy material? Same conditions apply...accordianman
Posted on Jan 21, 2008
  • Michael Borelli Jan 22, 2008
    I believe you have bass and treble controls,no? That would be your EQ settings...accordianman
I had the same problem. What I did was hard wire the fan so it runs whenever the unit is on. I had the reciever set for low impedance, when I turned this off all works fine. (Low impedance is only for speakers with an impedance of 6 to 8 homs or less)
Posted on Feb 21, 2010
2 Suggested Answers
  • 86 Answers
SOURCE: Sa-Da8 Overload and power off
you mite be pushing too much power, try unhooking a few speakers or check the wattage cuz that mite be your problem
Posted on Oct 22, 2008
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
Keeping your SA-DA8 cool
When I first bought this I noticed that it runs very hot even on low volume levels. I took it in for repair and told the tech that the fan didn't come on even when hot. He said "works as designed - the fan is output-power-driven, not temperature driven."
Wishing to prolong the life of ma SA-DA8, I used an old computer power supply and muffin fan. Plugged the PS into the controlled AC output of the amp, and the fan into the PS. Jumpered the "power-on" pins of the PS. Laid the fan on top of the amp, padded with some foam tape, and it now stays a lot cooler (and the fan is very quiet, though not silent.)
on Nov 05, 2011 | Technics SA-DA8 Receiver
My Technics sa GX350 tuner keeps going into overload. It's the only thing plugged in.
Hi mate, had the same problem with my amp.. Take the top off and there is a fan at the back, there are 2 piece's of copper flat wire that touch together and these do not touch anymore so when its turned up or the bass gets stronger it cuts off as the fan should kick in at this point. If you can get these to touch again (bend them) then the problem will be gone!! I have had to do this a few times now though so this is not a long term fix.. I may try soldering!
Jan 01, 2011 | Technics SA-AX910 Receiver
How do you download music
Hi Finch,
Try these links:
You can listen to just about anyone at
And here you can findthe top 50 music search engines:
Hope that helps
Dec 25, 2010 | Computers & Internet
Sound just stopped all of a sudden .....unplugged it for 30 secs still did not was on but it felt a little hot on top
Power amp output IC have an overheat. Cool it down and restart at
low volume. Send your e-mail if this did solve your problem.
Sep 25, 2009 | Technics SA-DA8 Receiver
SA8 5.1 receiver overload comes on with no sound
Try checking your fuse if it overloaded then it probably blew it
Oct 22, 2008 | Technics SA-DA8 Receiver
Jan 12, 2008 | Technics SA-DA8 Receiver
Technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Nov 30, 2007 | Technics SA-EX300 Receiver
Technics SA-DA8 Receiver Logo
991 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
