Question about Hitachi 43FDX01B TV
Hitachi TV Model 43FDX10B
Every once-in-a-while my TV will shut off and immediately the red power light will flash on and off continuously and not come back on until I turn off the TV for a while. I may leave it turned off for 15 minutes and get back to viewing or it may take as long as 1, 5, or 10 hours before I can turn it on again. Sometimes placing a fan to cool everything down, it will become operable. The most I've had to wait was 1 day. The least I have had to wait was 10 minutes. It seems that the sooner I place the fan for cooling, the sooner it becomes normal. I suspect the DVR cable box may be sending an illogical message to the TV to turn off as if sending a sleep message to the TV. I say this because it only happens when the DVR modem gets hot. That is why I use the fan. If I keep the fan running continuously, the problem rarely happens. However, my fan burnt out. Does anyone have a suggestion or a way to look at the problem differently?
The Superbowl will be coming up soon and I'd like to clear this up before then. Thanks, Jim
  • 1,067 Answers
Open it up get dust all out clean it well ok then ya use fans around it vented area to keep it cool its getting to hot dust build up
Posted on Jan 28, 2008
  • 3 more comments
  • nick helpap
    nick helpap Jan 28, 2008
    make sure it son a good power strip like monster cable for clean power from wall usa power grid is bad up down cuses issues on tvs heat # 1 tho get in ther clean the hell out of it blow it out best u can for wile work on it k then get fan going on it behind it they sell pc fans linked up in 4 u can stick in it have turn on when tvs on get heat away form the main power transformer cracks in bord will happen resolider eash one if u do see hair line cracks
  • nick helpap
    u need a fan also after u do a exstive cleaning to it ok otherwise u will lose it cose big money
  • nick helpap
    getthose pc fans off ebay for dvr also to help it ok u can turn certain fetures off too in dvr main master menu
  • nick helpap
    do u wanna link to these hi end fans 20 bucks
  • nick helpap
    buy these 4 pack then maby anther set for dvr shooting 2 in 2 out
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
Is my Hitachi Tv model 43FDX10B HD ready?
Probably but this hitachi has no reall HD just simulated, called D3VirtualHD by hitachi. Should work, you can always return the blu-ray if it's not what you expected or ask a good salesman if it's worth, you might try it in store...
Dec 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Red on/off indicator light never turns off
I had that same problem intermittently for about six months. Now I have no picture, just three small vertical lines in the center of the screen. One red, one green and one blue. Can anyone help? I know its outdated but I'd hate to throw the set in the dumpster if it just needs a little mainentance.
Jul 05, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
Hitachi 43FDX10B Power problem
Below is a few possible causes along with verified cures.
Intermittent shut off
Cause: Check auto link and 4 event timer. redress cabling from front control panel away from blue crt-yoke-hv lead
Symptom: shutdown
Cause: T701
Jan 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi rear projection 60" tv, power failure
Yes,it's worth it ! Check for bad C702 capacitor next to HV
transformer covered partially by glue and E994 open pico fuse
in power supply .part # for cap 1-161-754-00 102K / 3KV.......T.
Dec 04, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX10B rear projection tv
Do you have a cable box which turns on and off with the tv? If so is your cable box input on the video 4 mode? If that is the case look under the video menu for advanced selections, you will see a selection for auto/on/off for video 4, select off. Check manul under video and it will explain also.
Nov 30, 2007 | Hitachi 43FDX01B TV
Power light will not shut off.
Sounds like the main relay is stuck, if you know about tvs and what a relay looks like, you can take the back of and tap it with a screwdriver and it will clear up for a while but return, you will need to replac the relay. If not knowledgable call a technician for a repair.
May 29, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
if you can hit it and it does something it's telling me you have a loose connection. or cold solder joint.
Apr 28, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX01B TV Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
