Question about Nintendo 64 Console
Got nothing the red light comes on.. and I tried to jiggle the cables.. nothing.. just a blue input screen...
  • Vince_A Jan 26, 2008
    well i know its hooked up right, the power light comes on, the game is in right, the screen turns black, and i hear the audio try to kick in, but the screen just stays black. if i press the reset button, the screen flashes and brings up some kind of code. and it also says push button, the only button it responds to is the reset. when i hit the reset, it brings up the same code again.
    PLEASE HELP ME!!!!!!!
To test your wires I would try using the Cable or RCA cables on a SNES or Gamecube if you have those systems near at hand. Nintendo was nice and made universal RCAs for a while.
I have an issue like this and I know its not my wires, thanks to them working in my SNES.
Posted on Apr 28, 2008
    Problem Solver:
  • 16 Answers
You may have either a problem with your wires, or you may have a problem with the settings on your TV/VCR/DVD.
Posted on Jan 21, 2008
6ya staff
SOURCE:
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Screen goes blue on digilogic tv we have it set up with karoke machine we can get volume but no lyrics come up .
Blue screen on most TVs indicates that it is not able to see a signal on the input that is chosen. Most TVs have multiple inputs now, and some of the connectors share the same colors as well. I am betting that your karaoke box uses a 3 wire cable that comes out, 1 red, 1 white, 1 yellow that should go to the composite input on the TV. Here is the problem with that kind of cable. Very easily damaged. If you are sure that the input is set correctly on the TV, try replacing the cable.
Nov 02, 2009 | Audiovox Televison & Video
Cable input is not working
Sounds like you mabe be on the wrong source. Try hitting the input button on the side of the set to change inputs. Input channel up or down find tv hit input again. If on the wrong input you will only get a blue screen and message no signal that will apear for a few seconds.
Sep 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
There is no picture anymore, all shows a blue screen.
do you have the orginal remote that has device button on it such as tv,dvd,av1,av2 or a input button on it if so play around with it such as when the blue screen comes on press the tv button or even better if you have cable box with the red,white and yellow plug in the back just plug the red,white,yellow cable from your cable box to the red,white and yellow into
the input of the tv
Jul 31, 2009 | Televison & Video
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
No picture
hi..make sure the cable or dvd RCA inputs red,yellow
and white inputs are proper.There may be some loose
connections.
check it out..
thank u..
rate me..
May 05, 2009 | LG 42LC2D 42 in. LCD HDTV
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
When i turn on my ps3 the screen wont load up
when i turn on my console it comes on but nothing comes on the screen
Nov 23, 2008 | Sony Playstation 3 (PS3) Console
S-Video on the blue screen
menu has input selection to turn on/off or name video inputs.....T.
Oct 24, 2007 | Mitsubishi WS-48311 48" Rear Projection...
Nintendo 64 Console Logo
104 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
