Question about Pioneer DEH-P9200R CD Player
Buttons my buttons are shot the rubber on the track selection are worn threw ware can i get replacement buttons
  • 67 Answers
I may be able to get you a pdf servicemanual that contains part # 's
Posted on Jan 27, 2008
When i pump grease into the ajuster to ajust the tracks it goes slack again
The seals in the track adjuster are shot. This happens when the tracks stretch too much and make the adjuster go past its limit. If it is a rubber track it likely needs replacing. Steel tracks you can usually remove a link, replace the adjuster seals and you should be good to go.
Nov 06, 2013 | Multiquip Da7000ssa-1 Generator Kubota...
What is the world record for a shot-put throw?
Randy Barnes from the US holds the men's world record. HE threw the shot 23.12 meters in 1990.
Natalya Lisovskaya of Russia holds the women's world record she threw the shot 22.63 meters in 1987.
Jan 17, 2013 | Sport & Outdoor - Others
My Yes/enter button wont work, how do i go about replacing this or fixing it? i took it apart and the button does not work at all is there anything i can do?
The button will either be a switch type with a small switch actuated by the button or a conductive rubber pill that is pressed against circuit traces on the board. The latter you can clean with 99% isoprophyl alcohol and Q tips. The switch type you probably have to replace the switch as the internal contacts have likely worn. Often these switches are very small and take a lot of force given the size of buttons that actuate them. Unsoldering from the board takes care to NOT damage the circuit board and the pads. Make sure the new switch is held tightly to the board before soldering in place.
Feb 23, 2011 | Tascam 2488mkii 24 Track Recording...
Does anyone have information where you can get replacement rubber tires / wheel grips for Brio electric train engines? (wooden tracks) We have a few electric engines that can no longer climb the hills...
I dont know where you can get replacement tyres. But here is a fix for the problem:
Using tweezers then fingers, pull off the existing tyres.
Take ordinary sewing thread, and wrap it around the V in the wheels (where the tyre was), about 20 turns or so, keeping the ends inside the V.
Put the tyres back on.
The thread forces the tyres further out, making some tread from the rubber available above the level of the plastic wheel rims.
Nov 06, 2010 | Thomas and Friends Repair Garage Fits...
Water comes in but will not begin to wash
hi there......this problem is usually related to badly worn brushes in the motor...a quick way to check this is.....(1) remove the machine from its position...bringing it foward enough to tilt it back sufficiently allowing you access to the botom of the machine...(2) insect the motor for signs of black carbon dust...indicating brush ware....gently tap the motor with a small hammer...or suitable object....stand the machine uright machine....if all is ok machine will run indicating a set of replacement carbon brushes are required....failure to run indicates brushes very badly worn and possibility of damaged motor...remove the rear panel of the machine...remove the belt...remove the motor for inspection..of armature and brushes...any burn or discolouring marks on the copper brush track...indicates a failed motor..which will require replacing....
regards Sir Galahad
Sep 03, 2009 | Whirlpool Washing Machines
HP Wireless Mouse Left Click Doesn't Work
Try using a different mouse on the same computer if it work.... run a hard ware daignostic test on the old mouse.... and if you have purchased this before three months just get it replaced.... as it would be in warranty.... reply with any more queries....
Jul 30, 2009 | HP Computers & Internet
My cds are starting to skip all of the sudden.
HI, this will occur if the optics assembly stabilizers are worn. the tracking arm is supported by these stabilizers. they tend to ware overtime. you will need to replace the optics assembly asap.
Jul 25, 2009 | Sony CDP-CX70ES CD Player
Tracking problems
tracking is due to rubber belts and tires being worn, look inside and replace. PRB google it. this can be a tricky problem if you haven't done it before.
Mar 26, 2009 | Mitsubishi HS-U448 VCR
Idk how to delete!
You can download the manual for your camera here:
To delete photos:
  • Enter the playback mode.
  • Press the [Menu] button
  • Use the up/down buttons to select the trashcan (delete) icon.
  • You can use the left/right buttons to select single image, multiple images or All images.
  • Press the center (round) button.
  • Press the center button (repeatedly if doing multiple images) and then Press the [Menu] button again and choose OK.
That should do it.
Note that you can also delete photos quite easily by connecting the camera to your computer with the USB cable and deleting the images with Windows Explorer.
Jan 02, 2009 | Sony Cyber-shot® DSC-W120 Digital Camera
It sounds to me like the clutch is not working properly.
This may be an adjustment problem or signs of a worn clutch.
Try selecting 5th gear and with the handbrake on let out the clutch, if the engine stalls then the clutch is probably ok and may just need adjusted. If the engine doesn't stall then your clutch is shot and unfortunately its gearbox back out to fit a new clutch.
Dec 29, 2008 | 2000 Alfa Romeo 156
Pioneer DEH-P9200R CD Player Logo
57 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
