Question about Whirlpool Calypso GVW9959K Top Load Washer
My new whirl pool washer is leaking a lot of water
What can I do to fix it
Hey I just had a leak. it was the drain tube it had a small crack in it. I unhooked it - took it to a local appliance "yard" and got one for $5. works great now.
Posted on Feb 03, 2008
  • 770 Answers
Where is it leaking is that the question?? if i show you can you open the washer up to check?? are you mech. inclined?
Posted on Jan 27, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Flojet 2.9 GPM 50 PSI Water Pump pulses-no steady stream.
Is it whirl-pooling because the water is too shallow? One thing you can do to prevent this is to lay a piece of plywood over it. It will float and keep it from whirlpooling and sucking air.
Jul 02, 2015 | Psi Garden
Whirl Pool Duet Sport WFW8300SW00 leaks water from the detergent drawer after about 30 seconds of water running...please help!!
the water pressure is to high turn the tap down and wind the front feet right up. very common the water comes in to fast and splashes over the tray & down the front panel that will rust. replaced over 100 front panels still under warranty due to this problem.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirl pool 1400 has stopped working the
Them washer are what you call high efficiency washers.HE. They only use 1 gallon of water to wash them clothes. You go adding more than a teaspoon of soap and that washer is gonna have a cow. Over a period of time that soap gonna build upb50e111.jpg so much the washer is gonna just give-up the ghost. If you know you use the correct amount of soap there could be something in them pump.You need to remove the service panel41b08ad.jpg and take a looksee at that tech sheet and see what it say about them light flashing. While you at it you may as well remove that cap6349b09.jpg and clean out that filter. d081835.jpgThat might put yall back in business. That tech sheet will be in there by that white box which is the motor control unit. The other stuff that the tech sheet error chart might reveal is located on the topside.539a7ad.jpg Good luck on dat repair mon ami.
Jun 06, 2010 | Washing Machines
I have the zuma whirl pool tub. the jets go on
This is an automatic feature to dry out the pipes and prevent mold. The next time you turn on the pump after leaving these tubs for a few weeks you get lots of black **** in the water and this is what this feature prevents. Sounds like the tub is working fine :)
May 23, 2010 | NRS Zuma Tub Only - R7236T - Standard
I have a whirl pool duet washer with error code
try this:
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Apr 28, 2010 | Washing Machines
My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
F1 code
well they refuse to adress your issue under a warr. beacause of age , but im certain that a whirlpool auth. servicer will glady adress your issue. As for the F1 generally relates to a faulety control board. but would want( a serveicer ) to check in more detail before jsut askin you to replace the board
Oct 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Calypso GVW9959K Top Load Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal De
