Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Phone will not ring
skydive13 on Jan 21, 2008
i cant get my iphone to ring...it will only vibrate
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
Posted by sifuchar on Jan 29, 2008
May be obvious to some, but needs to be said: did you check the slider on the left side of the phone above the volume controls? If you see an orange dot here, slide the button down.
Same Problem
Apr 24, 2009
-   iphone does not ring -   bunaziua84
Apr 15, 2009
-   Thanks for the fix,been trying to fix ringer for three days now. -   Guest
Apr 07, 2009
-   thanx so much!  you think a MAC genius could have told me that over the phone or AT&T?  ha ha didn't even know i had that button!  thank you!  :}  yay my phone rings again :} -   jorierouge
Mar 30, 2009
-   iphone won't ring. Only vibrates. Seems to be stuck in silent mode. Switch on side works mechanically, but whether or not the red/orange button is showing it is always in silent mode. -   jtollemache
Mar 16, 2009
-   phone does not ring but it does vibrate-   Guest
Best Solution
posted on Feb 12, 2008
Very Helpful)
dobber719
Rank: Apprentice
Rating: 98%, 169 votes
Thanks, The orange dot on my phone was showing as well. That fixed the problem.
Was this helpful?
Yes
No
23 people thought this was helpful
Solution #2
posted on Feb 14, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
actually i had the same problem. i cudnt c the dot coz my cover was hiding it. hehe that slient swith was on thats was my problem :$
Solution #3
posted on May 11, 2008
Helpful)
Nimrod2007
Rank: Apprentice
Rating: 92%, 7 votes
Used to have the same issue of the NOT RINGING WHEN IN SLEEP but I downloaded an application called Insomnia from the utilities category in the installer application.
Iphone Its working now.
Might not be the correct fix but the phone is ringing when on sleep mode.
Hope everyone find this helpful.
Cheer to all
Was this helpful?
Yes
No
Solution #4
posted on May 13, 2009
Very Helpful)
uerym
Rank: Master
Rating: 80%, 39 votes
FIND YOUR SOLUTION FROM APLLE.
HERE IS YOUR SOLUTION
www.apple.com/iphone/prob237ji32/solution
Thanks
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Apr 19, 2009
Very Helpful)
pjdavis007
Rank: Apprentice
Rating: 100%, 3 votes
The obvious problem is the ringer switch, but something I just figured out on my phone was if you set an individual ringtone for each contact and no longer have that specific ringtone on your phone anymore the phone will only vibrate. Try looking through the contacts list and the ringtone applied to that number then make sure you have that ringtone on your phone. If not, more than likely you just have to choose another ringtone. Yay me!!!!!
Was this helpful?
Yes
No
Solution #6
posted on Mar 20, 2009
Very Helpful)
dogs330
Rank: Apprentice
Rating: 100%, 8 votes
See http://www.theiphoneblog.com/2009/01/01/iphone-101-iphone-ringing-meet-silent-switch/
Check the top button (called the silent switch) on the top left of your iphone . Push it towards you so the red dot is not showing. Now try calling the phone.
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #7
posted on Jan 23, 2009
Very Helpful)
jstarnes2
Rank: Apprentice
There is a button at the top of the volume slider which needs to be switched or flipped up.
Again it is located on the left side of the phone just forward of the volume control.
Was this helpful?
Yes
No
Solution #8
posted on Aug 22, 2008
Very Helpful)
JFK LIVES
Rank: Apprentice
Rating: 100%, 5 votes
Simple EASY Fix... soft reset: Hold menu bottom and power button at same time past power off, until you see apple. fixed mine!!
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #9
posted on Jun 24, 2009
Not Rated)
collywog
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem i tried everything. Then i figured out that i was after upgrading to 3.0 and had to jailbreak again. So i did not have the ringtones that i had downloaded before the upgrade that i had assigned to people. As soon as i downloaded the ringtones again problem solved. Hope this helps.
Was this helpful?
Yes
No
Solution #10
posted on Jun 10, 2009
Not Rated)
srh10
Rank: Apprentice
Rating: 83%, 3 votes
If all your switches are on....and your the ipod won't give sound either, go into settings, then general and hit the reset button on the bottom.
Was this helpful?
Yes
No
Solution #11
Not Rated)
asgder
Rank: Master
Rating: 78%, 9 votes
Hi Friends,
Problem with Apple iPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock your iPhone now you must Click Here.
If you have any other problem with your iPhone you can try the site by Click Here. May the site can help you.
Was this helpful?
Yes
No
Solution #12
posted on Aug 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Its really nise to get reply which works well thanks a lot
Solution #13
posted on Aug 18, 2008
Not Rated)
vpalaciov
Rank: Apprentice
Rating: 0%, 0 votes
My iphone was not ringing. I click the icon Ringtones, click start converting, click direct ringtones, click Enable Ringtone - MUST BE IN OFF position and Enable Star effects - MUST BE IN OFF position. Try and enjoy your I-phone.
Was this helpful?
Yes
No
Solution #14
posted on Jul 24, 2008
Not Rated)
bluevegas
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the Insomnia App suggestion Nimrod2007! I downloaded it and everything is working again.
Was this helpful?
Yes
No
Solution #15
posted on Jun 01, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
DIDNT WORK AT ALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Solution #16
posted on May 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same not ringing in sleep mode problem. What i did was used my back up phone and i turned off the iphone for a week. After the week went by I said i would give the iphone another try and it works normally. So give it a try, what do you have to lose!!....keep me posted, maybe I own a freak iphone.
Related Problems
bluetooth to other mobiles
It was in a case and worked for an hour after being dropped,...
Can you Help with these PDA problems?
iphone problems
Solve
How do you reset your iphone?
apple iphone screen blocked on text...
Solve
Stuck on text message screen and not able to go forward or backward
SCREEN MAGNIFIED BY ITSELF
Solve
the home screen magnified by itself, now i can't enter the unlock code because the screen is so... (More)
57 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 21, 2009
had the same thing - thanks for sharing the orange mystery
Comment by Guest, posted on Jan 27, 2009
I had the same problem. Turned out that microscopic orange button was on! ugggh
Comment by Guest, posted on Jan 26, 2009
Man, do I feel dumb! Thanks for your help! :)
Comment by GerryGO, posted on Jan 07, 2009
My phone will vibrate but not ring for incoming calls.
Comment by steve680, posted on Dec 31, 2008
iphone will not ring only vibrates
Comment by rickgama, posted on Dec 12, 2008
my iphone 2g wont answer incoming phone calls from the touchscreen also wont ring only vibrates regardless of where the switch is.
Comment by digipro3, posted on Nov 26, 2008
my iphone will not ring but only vibrates
Comment by Guest, posted on Oct 25, 2008
iphone 3g suddenly says NO SERVICE. AT&T states I am getting good service. Phone just stopped working.
Nice work, APPLE!!!!!
Comment by jasmedi, posted on Oct 22, 2008
my phone will not ring but vibrates
Comment by jedimook, posted on Oct 19, 2008
phone is on. connected to the tower. friends call... they say my phone rings twice then hangs up on them... but it never registers on my iphone.
this is quite problematic and incredibly frustrating.
what should i do?
Comment by Guest, posted on Oct 16, 2008
my iphone isnt ringing either. i reboot, etc, nothing only vibrate.
Comment by Guest, posted on Sep 05, 2008
my phone will not ring.
iphone does not ring only vibrates
Comment by msmcfadden, posted on Sep 04, 2008
my iphone is not ringing it only vibrates
Comment by kreeg, posted on Sep 02, 2008
First generation phone has not been ringing- only vibrating even though it is set for piano riff. Have tried rebooting but to no avail. Thanks for your help.
Jerry Kreeger
Comment by faithbuilder, posted on Aug 26, 2008
My iPhone does not ring anymore with any incoming calls, only vibrates?
Comment by dittz ana, posted on Aug 26, 2008
no ringing tone only vibrate. how to open.
Comment by Guest, posted on Aug 08, 2008
Hi I had the same problem with my iPhone not ringing,and I slid the red button on the side down,and now it is ringing ! Hope this helps !
Comment by Guest, posted on Aug 06, 2008
I and 3 other iPhone friends are only alerted lately by Voice Mail rings. Someone will call and the phone won't ring, but we get a voicemail.
What's up?
Comment by wkeith, posted on Aug 05, 2008
phone does not ring with incoming call
Comment by daryl_leo, posted on Aug 02, 2008
my iphone will not show incoming calls or let me dial out or send sms
Comment by Sp00ks, posted on Aug 01, 2008
my phone does not ring or vibrate and even if i go to select a ringtone for sms or tap on the keyboard.
Comment by Jambalaya, posted on Jul 29, 2008
16 GB 3G White
Phone won't ring (although ringer is on) but will only vibrate when phone is "resting". Haven't put phone to sleep (by pushing to right silver button), just let screen power off automatically.
These AT&T tech "Mac" people are unprepared to help. They're not trained and it's nothing like calling AppleCare where they know a's going on.
Comment by Guest, posted on Jul 23, 2008
it vibrates but won't ring or give sound warning for sms
Comment by 241122, posted on Jul 22, 2008
Phone does not ring or vibrate on incoming calls
Comment by pbpools, posted on Jul 20, 2008
phone will not ring when I get a incoming call.
Comment by Guest, posted on Jul 19, 2008
i cnt get my iphone to ring
Comment by Guest, posted on Jul 16, 2008
phones won,t ring
My iPhone will not ring when i get a text message
Comment by Guest, posted on Jul 07, 2008
reboot
Comment by Guest, posted on Jun 27, 2008
produces no sounds only vibrates
Comment by ryha, posted on Jun 08, 2008
Same here. Once my iphone got frozen, and after that it stopped ringing. It can only vibrate. However when I switch off vibration mode it doesn't produce any sound while receiving the calls. What should I do?
Comment by cnowels, posted on Jun 07, 2008
My iPhone only rings when it is not in sleep mode.
Comment by Guest, posted on Jun 03, 2008
will not ring when called. in settings only vibrate is an option?
Comment by Guest, posted on May 17, 2008
my iphone does not ring, only vibrates
my iphone does not ring, just vibrates
Comment by MissEtiene, posted on May 11, 2008
Iphone will not ring... Sound works... but no ring only vibrate....Help...
Comment by Susannewest, posted on Apr 22, 2008
My iphone does not alert me to incoming calls - it is a real pain as I use it for work!
Have adjusted all settings in the hope that the phone was on silent mode.
I am thinking of chucking it - so frustrating!
Susanne
Comment by sukhises, posted on Apr 20, 2008
My iphone is ringing only when it is not in the sleep mode once it goes into the sleep mode it stop ringing when call comes.
Comment by Guest, posted on Apr 16, 2008
the ringer and when someone calls the iphone will not ring, what do i do?
Comment by tikva, posted on Mar 09, 2008
When somebody calls you the phone only vibrates no ring sound. Did everything reset and all still no ringing sound.
Comment by Guest, posted on Mar 02, 2008
Check out post sifuchar, posted on Jan 29, 2008. I completely forgot about the button and could not see it under my iPhone cover.
Comment by Guest, posted on Feb 26, 2008
Iphone vibrates but I can't get it to ring. How do I correct?
Comment by tbarrat, posted on Feb 20, 2008
iPhone does not ring with incoming calls.
Tom
Comment by Guest, posted on Feb 13, 2008
Same as the others. My phone does not ring with incoming calls. I have repeatedly talked with AT&T and Apple genius (not so much of one). Nothing is on vibrate!!!! Side button is not on red, etc., etc., etc.!!!!! Help. I'm on with AT&T right now and gee whiz. We are doing the same things we have always done!!!
Comment by joerocket, posted on Feb 13, 2008
My iphone will not ring when it is in sleep mode. Once awaken it will show all the missed calls and voicemail messages. If the phone is docked its fine. HELP!!! 1.1.1 jailbroken
Comment by jqob1, posted on Feb 08, 2008
I have the same issue. I thought I heard about a fix or a patch solution for it, but i cannot find it. I remember it was a source for Installer, but I can't find it.
Comment by DrBuz, posted on Feb 08, 2008
I have the same problem. The iphone rings sometimes, usually not. If I call my iphone from another, the calling phone sounds like the iphone is ringing, but the iphone is silent. It is not the slider, mute, or vibrate modes.
Comment by mickeyy27, posted on Feb 07, 2008
me 2 have same problem.no ring for incoming calls,key pad,text message send & reciving,only vibrate.But ipod works from phone speaks,you tube works,also when goes to sound setting it sound.I tried to deleted all app and game etc when i download from installer,still not sound.Anyone can help please .BTW my Ipone is 1.12 unlocked.
Comment by Guest, posted on Feb 03, 2008
No ringing tones are working with incoming calls
Comment by Alavian, posted on Jan 29, 2008
I have same problem
Comment by Guest, posted on Jan 28, 2008
1.1.2 iphone does not ring incoming
Sponsored Links
Describe your PDA problem:
Top PDA Experts
Rank: Guru Guru
Solutions: 702
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more PDA Experts
Top Computers & Laptop Repair
(601) 918-0222
I will connect to your Computer and repair the...
(330) 502-6853
Instead of lugging your computer into a shop and...
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
