Question about Car Audio & Video
Remote start on car
Hello, my boyfriend borrowed my car quite some time ago and somehow messed up my remote control so the car won't start remotely anymore. When I push the button on the remote to start the car, the lights flash five times then the horn honks and the doors lock remotely. The lock/unlock buttons and truck release still works but the car does not "chirp" anymore when I lock the doors remotely. Also, since this car is a 1999 Pontiac Grand Am SE it has a passlock system. The light on the steering column used to blink when the car was off and was solid when the car was on. Now it is solid all the time. I've tried to get answers at the Automotive Forum on the internet and at the Surgenor Pontiac Buick dealership, no luck. By BF says he only pushed the buttons on the remote so I am thinking he messed up the programming or something. Hope someone out there can help me before we get to -30C here in Ottawa, ON Canada. Many thanks to those who try.
  • Nicole Beaucaire
    Nicole Beaucaire Jan 24, 2008
    Quite helpful and funny too.
  • 2,039 Answers
It seem our remote is deactivate you mush have a bypass switch or valet switch maybe it off because if the module would be blown nothing would work lock under the dash i understand about cold im in montreal cheers p.s get ride of that boyfriend who mess with our car take care
Posted on Jan 22, 2008
Why won't tv turn on by remote or power button unless we try 4-5 times?
My TV has the same problem.
At first, it was an issue with the button itself, somehow some gunk got down under the button and kept it from pressing down all the way most of the time.
A few days after we fixed that, it started to mess up again, this time it was an issue with the way it transmitted signal to the TV.
If the button being blocked isn't the issue, replace the batteries. If the batteries aren't the issue and you don't have a soldering gun, then you'll need to purchase a new remote.
I bought one from walmart for ten dollars and it works just fine for basic use.
Jan 15, 2013 | Televison & Video
GVA remote has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 10, 2012 | Televison & Video
The sensor on the TV for the remote control seems to have stopped working
Good luck.
Jan 09, 2012 | Televison & Video
The FDA is lock and the TV wont stay on
Hello
The lock of RCA TV can be unlocked. You must have its original remote control to do this. If you haven't one, buy a new one or just borrow it from any of your friends or relatives who own the same model RCA TV you have. To unlock it, try these methods. One amoung them will surely unlock your TV.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Sep 23, 2011 | RCA TruFlat 27F520T 27" TV
I accidentally turned on the fpa lock and don't have a remote. What now?? Any hope? I also could not get the CC up before I got locked out.
Hello
To turn out FPA lock with RCA TV, you must have its original remote control handset. If you haven't one, just buy a new one of borrow it from your friends or relatives, who own the same model of RCA TV. After unlock, you can use any other remote control. If you are using the original remote control, do the following to unlock it.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Sep 01, 2011 | RCA TruFlat 27F520T 27" TV
I have and rca tru flat tv and my FPA lock is on... i have a brighthouse remote that im using on it but i need to know how to turn it off
Hello
Without its original remote control, opening the FPA lock of RCA will be difficult. Just try to get one new remote for this set or jut borrow it from any of your friends or relatives who own the same model set, just to open its FPA lock. After opening lock, you can use your brighthouse remote. You can open the lock with one amoung the following procedure.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Jun 27, 2011 | RCA TruFlat 27F520T 27" TV
How to unlock FTA?
Hello
you must have its original remote control to unlock the set. If you haven't its original remote handset with you, try to borrow it from any of your friends or relatives who owns the same model. After unloking it, you can use universal remote.
OK.
Jun 25, 2011 | RCA 20F512T 20" TV
My universal remote went out and somehow the tv-a Sansui-got switched from channel 3. How can I get it back to channel 3 so the converter will work? I tried changing channels manually at the tv but it...
Look in the owner's manual for instructions on having the TV scan channels. Make sure the converter is on before starting the scan. If that doesn't work, you'll have to buy or borrow a universal remote to take care of it (enter 3, 03 or 003 on the remote control). This will happen every time you remove power to the set, whether it is unplugged or you have a power failure, so start saving up for a new remote control.
Dec 07, 2010 | Sansui 27" TV
Broken screen for logitech harmony 1000
I can fix your screen and replace it with a new one. My dog bit my harmony 1000 and shattered it. I have also replaced a harmony 1100 screen. I have been in electronics industry a long time and considering repairing lcd screens on harmony 1000 and 1100 remotes
Dec 19, 2008 | Logitech Harmony 550 Remote Control
Panasonic Viera Remote Control is locked
I had somehow hit the SAP button! Turn it off, and you will get the use of your remote back! :) I don't know about your remote, but on mine I just had to hit SAP.
Feb 09, 2008 | Televison & Video
Car Audio & Video Logo
78 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
