We need to replace the motor fan on our Lake Air Maxum air cleaner... Where can we get a...
(More)(More)
We need to replace the motor fan on our Lake Air Maxum air cleaner... Where can we get a replacement?
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
How do I calculate impedance in a four wire test. i.e. I am passing a 1 amp (A.C.) current through 2...
(More)(More)
How do I calculate impedance in a four wire test. i.e. I am passing a 1 amp (A.C.) current through 2 x 10 ohm resistors. One of the resistors is connected in paralel with a switch. When the switch is closed it shorts the resistor causing a voltage drop accros this resistor. The switch can be coated with certain contaminants and it is the impedance of these contaminats I am trying to measure. I measure the voltage accross the two resistors and the current phaze difference between them. How can I use this data to calculate the impedance of the contaminant?
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
