Question about HP Pavilion dv6000z Notebook
Dead set good day, when i swicth on my laptop only the mouse wheel will light up for 1 second and nothing happens. and the indicator light of a power cord connection is just blinking with orange color. can you pls help me with this problem? thanks a lot...
  • jofern Jan 21, 2008
    good day,
    thanks a lot...
    Genius:
  • 1,067 Answers
Soudn like sdead batttery let it charge for wile maby need to buy new one or charger
Posted on Jan 21, 2008
Swicthed off with the remote last night, to day the red light on the left bottom side is off. Can't swicth on, the remote or the panel. help please.
Try unplugging it & while pushing the the main consul power button in for 30 seconds, that happen to me, it was just dead.. its like losing a friend, I was almost in tears, I did the unplug & hold power & it came back on. it might not work but its worth a try
Jun 01, 2015 | LG Televison & Video
Toshiba Satellite laptop will not boot. Shows power from outlet and battery but no indicator light is present for the last two in the five light sequence.
Its an old trick that got my Dell laptop working
Unplug the laptop remove the battery press the power button,...nothing will happen, wait a few seconds put battery back in laptop plug it in hold upside down press power button until it boots
If that doesn't work it could be a bad/loose/dead bios battery What is the model of the laptop?
May 11, 2011 | Toshiba Computers & Internet
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
Toshiba satilite P100...wont turn of
Try these:
1. Can you plug something else besides your laptop into the outlet...verify you have power?
2. Is there a light on your AC adapter...when you plug it in?
3. Try removing your battery and plugging it in, and verify that your AC adapter is working (somehow, if it has no indicator light)
4. Then unplug it, put the battery back in and see if it will start.
Let us know what happens after you try these.
Apr 12, 2009 | Toshiba Satellite P100 Notebook
ASpire 5580 series, no power
Hi Dhadha,
Try this: - remove AC adapter plug - remove the battery - insert the battery again. - try power up the laptop.
I have same problem, but this trick always work, and I always do this every power up. :)
However, I am using a usb optical mouse for an indicator. When inserting the battery, I check the light on the mouse. If it is flashing the second I insert the battery, then the power up will be successful. IF it is not, then remove and insert the battery again.
Try it.
Regards,
Dapid Candra
Nov 17, 2008 | Acer Aspire 5580 Notebook
Raidmax 500w power slowly died, then wont turn back on.
1.-Your CPU fan is working?
2.-Your Power supply fan is working?
If not and following your description I think that you have to replace your power supply.
If you have the light on in the motherboard doesn't mean that your power supply is good.
Check the first to points above and if 1 and 2 are not working
Replace your power supply.
Let me know how it is going!
Thank you for using FIXYA!
Don't forget to rate my help
Pablo :-)
Oct 13, 2008 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
Dell Inspiron 9200 stopped working does not power on
This is a very useful post from LapTopReapir-101
Laptop is DEAD. How do your troubleshoot the problem?
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?...
For more in this article please click on the link below.
if you have other questions just lemme know
Sep 19, 2008 | Dell Inspiron 9200 Notebook
Synaptics touchpad totally dead no response!
Right click the Synaptics Pointing Device and select Pointing device properties OR double click the Synaptics Pointing Device. A Mouse Properties Dialogue is displayed, then select the Device Setting Tab and then select the synaptics device under device section then select the enable button and lasting select the the Apply button.
Jul 08, 2008 | Computers & Internet
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
HP Pavilion dv6000z Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
