Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher SHU66C02UC
I have a bosch dishwasher SHU66C02UC the timer ( electronic timer ) will not change and you can hear it running but has no water in it. Please let me know what you think.
    Novelist:
  • 130 Answers
You have water in the base of the machine. There is a flood float in the bottom so if any water gets into the base, it will shut off the water and run the drain pump as long as the power button is on. So shut off the breaker, remove the toe kick, and remove any water that is down there. Now start the machine and see if water is leaking into the base. If there isn't any water, an the dw is still running the drain pump, then with a wooden spoon raise the red plastice stick on the left side of the dishwasher up and down. It is possible that the overfil float is stuck. If this makes the dw start filling, then run cooking oil thru the dishwasher on the scrub cycle to remove excessive detergent. If you are in hard water, then the water deposits have caused this. Run citric acid ( Tang orange drink, Dishwasher Magic, or such) thru the dishwasher to remove this.
Posted on Feb 02, 2008
My Bosch SHU66C02UC dishwasher stopped midcycle with water in the bottom. We checked the fuse and it is fine. I'd rather not pay for a repairman as it is quite expensive.Thank you.
Some suggestions: try pushing the drain/cancel buttons and see if that drains the water; check the filter or trap in the bottom of the dishwasher for blockage; check the hose that links the dishwasher to the under-sink drain pipe for blockage. You could google the model number and find the owners manual, which might have trouble shooting suggestions.
Sep 05, 2017 | Bosch Dishwashers
Dishwasher goes through cycle but when finished it is cold and code E..09 appears
Bosch Dishwasher Troubleshooting ' Dr. Dishwasher
www.drdishwasher.com/troubleshooting/manufacturer/bosch/
Your Bosch dishwasher can run a test cycle which will quickly go through each ... You can find a list of Bosch dishwasher error codes and their definitions here.
Jul 26, 2015 | Bosch Dishwashers
Model SHU66C02UC /14
never saw one with cotton pad . call a repairman
Jun 09, 2015 | Bosch Dishwashers
Electric smell bosch dishwasher
Do not use this appliance until you have check if it is one of the bosch dishwashers subject to a recall repair. Use the link below to check
http://www.repairaction.co.uk/bosch
Apr 16, 2013 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch shu66c02uc dishwasher has much longer cycle run times than it did the first 4 years we had it, also stays stuck on 1 or 2 minutes remaining for 30 minutes or more. Just doesn't clean any more.
Sounds like the filter is clogged. If you can and want to try to fix it yourself open door all the way after unplugging it or disconnecting power. Look under the top and you will find screws that you can take out and pull cage out. Then look at all of the drains, filter(s) and see if anything is clogged.
Jan 05, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 22, 2008 | Bosch SGV56A13 Built-in Dishwasher
Bosch dishwasher SHU66C02UC - Rinse Agent issue
Does soap draw open at right time?
Same solenoid opens soap draw as injects rinse aid.
Turn up hardness counter ?
Any blockages in dispenser unit its-self?
OTHERWISE CALL IN THE PROFFESIONALS !
Apr 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher
If you coud describe where you hear the noise that would be helpfull. the noise could be somethig hilling one of the spray arms or something stuck in the pump impeller. if you only wear it when it is only in a wash cycle I would say it may be someting in the wash pump. But also make sure the spray arms are moving freely
Jul 19, 2007 | Bosch 24 in. SHV66A03 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
668 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
