Hi, probably 2-4 years ago i was listening to the stereo when the power went out. when it did, i was unable to change time,alarm,station,presets or any of that. but the am\fm button, aux, tape and cd buttons work. another problem i have is that the cd doesnt work, it goes ot cd but doesnt open or play. also sometimes the unti will turn off, the 3 cd drive lights will remain on, but i cant turn it back on. it just stays with teh 3 cd lights on as well as the red power light. i have no clue what the problem is, most likely electrical\ a fuse, but im fed up with not being able to use it for its intended purposes. anyway any help would be great, thanks.
SOURCE: JVC mx-kb30 Stereo comes on then goes right back off.
A desperate longshot but the only i have to offer: It might be a problem with the electricity. if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person. Good luck
I have my manual here.
"Turn on the system and enter CD mode. While pressing the stop button on the unit( the little circular button with the dark square), press the CD Open/Close button on the unit. 'UNLOCKED' appears on the display."
Hope this helps.
My JVC MX-J800 is driving me crazy. The power comes on. But when I try to play a CD. I get the message that no CD is in the player - same message for all three CD players. What do I do?
