Question about Polaroid DRM-2001G DVD Recorder/HDD Recorder
DVR recording records to HD okay but when I start recording to a disc the process dies at about 7% or sometimes does a rush though after which the unit will not finalize the disc resulting in another coaster. Does something need cleaning, replacing, initialing, or am I to purchase another unit?
Open the unit and check the connexion of the burner
Posted on Mar 15, 2008
Problem Pioneer DVR-520H
your lens needs to be replaced.
Jan 27, 2008 | Pioneer DVR-520H DVD Recorder
HOW DO I GET MOTION DETECTION TO WORK?
Are you sure the cameras are capable of motion sensing and make sure that you do not need an additional control cable to the camera to make that work.
Jul 17, 2014 | First Alert Home Security
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't record in HD. DVR shows to be recording, but when you click on the programmed HD channel (the one that's supposedly recording) it's blank and says "searching for satellite". Just started recently.
Have you tried rebooting the DVR and removing the card that came with the DVR if its one that was provided to by one of the satellite company's such as Directv or Dish.
Nov 30, 2009 | Directv HR22 500-Hours HD DVR
Intermittent Recording
in you menu change your video format , check all settings,what type disc are you using ? are you recording to hd or to dvd, ? check your
firmware update
still have problems call 0403960527 jeff
email jcshepard55@hotmail.com
Feb 16, 2009 | Panasonic DMR-EH75 DVD Recorder/VCR/HDD...
Panasonic DMR-ES30v Combo- Message of "Check disc for error"
Pay TV in Australia will record "no problem" BUT BUT when it is a pay per view or Box Office etc it will be blocked in a similar way as Macrovisin that is recognized in the encoding of the recording device that the signal is passing through. The result point blank displayed you are not allowed to record this program or it is blocked or distorted part of the way through the recording etc...
Dec 31, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Cyberhome DVR 1600 DVD
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Pioneer DVR 640 H
You may have CDs stored in the Jukebox taking up space- if so delete them.
You may have images stored in the photoviewer - again, delete...
Have you done any disc backups, and forgot to delete the backup file? Goto bottom of copy menu for disc backup, then in the disc backup menu, choose delete backup file.
Jan 04, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Polaroid DRM-2001G DVD Recorder/HDD Recorder Logo
99 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
