Related Tags:
This problem should be removed because:
Problem with AMD Motherboard, nForce4 SLI, S939, Athlon 64/64FX/64X2, Max. 4GB DDR, 8 SATA, 2 IDE, GBE, 1394a (NF4SK8AA8EKRS)
how to install a amd motherboard
i dont know what the model is but i do know its a amd motherboard and i dont know how to install the power switch and reset switch and the led lights on the motherboard
i thinks thats what it is but i dont know how to find out
Solutions (1)
Best Solution
i can help ya do u have yahoo msg and is it 12 pins ? says buy it pw for power start red one there then verticaly across and so on let me know if u yahoo yahoo msg or chat with me on here
Pls help how to install reset led, powerled, hdd...
Please help how to install reset led, powerled, hdd led in SiS-745 Motherboard.
Just installed a new motherboard model MSI 790FX
Just installed a new motherboard model MSI 790FX - GD70 and new ram and cpu to go with it. plugged everything in and check all the...
I installed the mainboard and I'm not getting...
I installed the mainboard and I'm not getting the computer to come on. I get a green power light, but when I push the power button, I...
dont seem to have enough front panel pins for all
dont seem to have enough front panel pins for all my case wires
Add Your Solution
All problems have been solved!
Fix-O-Meter
505
505 people viewed this problem
- 0 people are following this problem. Be the first!
Top AMD Motherboard Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
i only have aim or yahoo msg its the 12 pins on bottem right area ok if u have anther computer u could almost match it up in lite leter says ps power switch plug in that pin red wire firrst then ove rto other pin then reset ide pled all u relly need
hdd is hd lights led is activety rst reset switch p power
all u nee dto do it get that p and rst switch on right way ok follow wire from main power re white or black go red to p pin then over next to it black ok not up down dont do that acorss oly it wil go one way or other test it to lights up ok
great job buddie it wont hurt moving them around to test right are go so on idd if u want see hard drive working make map so u know for future ref but that show u would do it good job thx nick
