Question about Motorola Mobility RAZR V3i Cellular Phone
Phone will not power on and battery is good
I've tried the battery in an identical phone and it's fine...the phone gets really hot if i try to put it on the charger. i can not get it to come on. i don't know if it's fried or what. please help me!!! thanks
    Sergeant:
    Champion:
  • 241 Answers
Hi check under your battery if the sticker is white or pinkish
it sounds like a sort of water damage occured
if NOT, then its a board issue - it will be about 60-80$ to replace
Posted on Jan 23, 2008
Batteries and phone very hot
There is a short in the phone that causes a high rate of battery discharge resulting in a overheating battery.
This cell phone is faulty and I suggest you get a new cell phone.
May 21, 2013 | Nokia 5130 Cell Phones
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
All windows and sunroof stopped working. They worked before I hooked up a battery charger/starter to it. I thought I saw some smoke coming from under passenger dash. Any ideas on how I can get them all...
Check the relays. There just under the driving wheel inside a closed box. Just take off the box and you should see about 7 relays. The big one in the far right corner controls the delay mechanism for your windows #4. What I discovered is theys relays can get really hot and just stop working. No wonder why my windows stopped working when the inside of the car got hot.
If there really hot, then try replacing them and see if that helps.
But first make sure you find the relay that controls the power windows.
These relays are designed for delay response, like our head lights or your power windows so they can still function after you've taken your key out of the ignition.
Apr 27, 2012 | 1996 Ford Explorer
Camera wont come on battery gets really hot
if it is a digical if so the batteries have to be rechargeable and be over 1000 because the rest just arnt good enough . because of the technolgy in the camara , and because of what it can do do . the batteries have to be the best . their will be more power comeing out of the camara and excceds the battereis. its like a mobile phone , the phone is a 16 volt batteri and you plug a 5 voult charger in the phone . it gets realy hot because their is insufficaint charger for the volt . we wiill have almost blew the charge on the batteris aswell as the connection on the camara or ie [phone]. leave for 24 hours and then try the rechargeable energizer 2000 plus is one of the best .replace the old for new and try the enegizers
Mar 30, 2012 | Sanyo VPC-T1060 Digital Camera
I have a 1992 gmc serria 1500. Some times it does not start. if i wait awhile and go back to it then it will start up right away. when it does not start the power turns on and does not even try to turn...
Assuming you've got a clean and tight connection to the battery, there's a good possibility that the starter is bad. A bad starter will occasionally work when cold but once it heats up, it requires more power to get it to engage. If when it's hot, everything else is working, ie headlights bright, accessories like power windows work, then it would certainly sound like a starter problem. Most with these symptoms end up changing out batteries, alternators, only to find out that a few days later, the problem returns and you've already spent a few hundred dollars. If you like, you can take the truck to 1 of the auto parts chains that offers free electrical diagnostic tests. This would confirm your battery and alternator are fine prior to making any major repairs.
Jul 29, 2011 | 1992 GMC Sierra K1500
Battery smokes gets very hot
Dose this happen with all batterys or just one battery . If its one the battery is no good. If this all batterys you try to use then there is a short in the motor in the gun likely in the windings and it was defective when you bought it. check your warranty
Jan 15, 2011 | Dewalt 18 Volt 18v Cordless Drill Switch...
Battery is dead, should it still power up if plugged in?
It will only power up after the battery has some charge in it.
If your battery is bad, it wont power on at all no matter how long you have it plugged in.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Mar 17, 2010 | Audiovox PPC 5050
I have a motorola v3xx cell phone that will not power on or charge. I charged the battery in a different phone, but it still would not power on. The phone has not been wet, nor been dropped. What is...
Sound like your phone is done for.
But try this first.
Remove the battery, remove the simm card. Wait 10 minutes.
I can assume the battery is good (as that's the #1 reasons for phone problems) Unless you can test the battery with a meter or use the battery in an identical phone don't assume its good.
Then replace the simm, put tha battery back in and give it a try.
Doesn't power up.?? Head on over to the phone store of your choice. Good luck.
Jan 21, 2010 | Motorola Mobility RAZR v3xx Cell Phone
Nokia 6030 data transfer
try to remove the battery on your mobile and press and hold the power button for 10 secs. try to put in the battery. try to power it on. if it doesn't work try to ask your friends if they have an identical phone as what you have, try to borrow their battery. if it works then you need to replace the battery on your mobile.
Sep 17, 2008 | Nokia 6030 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
