Question about Edirol UA-25 External Sound System
Edirool ua25 hi I am useing ua25 edirool and I get a sound of sshhhhhhhhh I test it and even went and took a looner I wused all diffrent output, headphone can you please help thank you
  • Koen Mar 02, 2008
    When I insert for instance VST in a midi track and one of the plugins you can find there , I get constantly that sound of shhhhhhhh when I play my keyboard.
    Please help.
    Thanks a lot.
  • 57 Answers
What version of windows our you running, you might have to go to control panel and make sure it is the default audio out
Posted on Feb 11, 2008
Ua25
Hello. Sometimes the USB voltage is not enougth. Try connect the usb cable into another USB port, preferring the rear panel connectors. The UA25 drivers must be installed previously.
Feb 07, 2013 | Edirol UA-25 External Sound System
Connected samsung TV to PC vi VGA cable as suggested by samsung support. Visual working correctly, no sound output. Tried hooking up standard audio jack leads with l-r splitter to TV to get audio. No...
You need a seperate speaker system when your tv is on vga there is no option to recieve a sound input. In fact if you hook your cables for sound back up to the tv you will probably find that there is sound but on a diffrent input channel. The other option is to use a diffrent type of connection like hdmi if your computer and tv support it which DOES support audio and vido throught the TV.
Mar 09, 2011 | Samsung Televison & Video
Alternator not working could it be a blown fuse...took the had the battery tested already..
no ,I dont think so, I think your alt has had its best days and has went iinto retirement,you can have it tested on the car without removing it to be sure.
Sep 05, 2010 | 2007 Infiniti M35x
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
Edirol ua25 jack speaker output
Your are using powered speakers right? Or going into an amp and then the speakers, as the UA-25 does not have enough power to drive passive speakers.
Call Roland customer service and have them walk you through the device setup to make sure you've got everything right.
EB
Jun 06, 2008 | Edirol UA-25 External Sound System
Cant hear recording in Logic 8 with the UA25
i have a mac and UA25 and there are no problems.
Mar 01, 2008 | Edirol UA-25 External Sound System
Cannot record
some driver has been installed by your device...to go back, do you have "system Restore" turned on? if so, try restoring XP to a time before your device
May 27, 2007 | Edirol UA-25 External Sound System
Vertical flickering color lines instead of pictures
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
Mar 16, 2007 | Sony PFM-42X1 Plasma TV
Edirol UA-25 External Sound System Logo
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
