Question about Mitsubishi VS-60601 60" Rear Projection Television
Mitsubushi Big Screen TV Screen Protector vs 60601
While moving a Big Screen Mitsubushi TV the Screen Protector flew off while going down the interstate. Can this be ordered and replaced? Can't view the tv without it.
Acutally the Lenticular screen (outer ridged screen) can acctually be replaced with something as simple as a shower curtain. That is what I ended up using as I could find nothing to replace it.
Posted on Apr 26, 2008
  • Mitsubishi Master
  • 8,617 Answers
That will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Posted on Jan 21, 2008
6ya staff
SOURCE:
Where is the Convergence IC on my Mitsubishi VS-60601 1997 Serial #104094. You told me what the problem was with my TV and showed me what a Convergence IC looks like, but now that the projector TV is...
Convergence IC will be mounted on a big Aluinuim Heat Sink They are Big Black ICs and will have Parts # on Them example STK392-570 There is 2 of them together.
Mats Electronics has them 1-800-628-1118
Nov 04, 2010 | Mitsubishi VS-60601 60" Rear Projection...
No Picture On Screen
it sounds to me like your tube has gone , go to your local tv repair shop and order a new tube its quite cheap to do so and they should be able to get it you quite fast.
Mar 10, 2009 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi big screen model VS 60601 convergence adjustment
you need new convergence ICs. If you can respond to this same post and verify the model number of your mitsubishi, I wll post the correct ICs that your model needs.
Aug 17, 2008 | Televison & Video
Mitsubishi
Lenticular is the inner screen and protective screen is the outer screen
Jun 16, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Trouble!!
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi big screen tv model vs-5062
HEY DOG-UNLESS YOU ARE GOOD W/VOLTMETERS THIS TYPE FAILURE ON THIS MODEL TV CAN BE VERY DIFFICULT.THE BEST ADVICE I CAN GIVE IS CALL A TV TECH EXPERIENCED W/MITSUBUSHI TVS AND GET AN ESTIMATE.
Nov 14, 2007 | Pioneer PRO-200 60" Rear Projection...
VS-60601 Mitsubishi Problem...
That model is famous for the CRts leaking onto the chassis which causes all kinds of problems and can cause the main circuit board to short as well as destroy the solder. Try looking at the board for evidence of a pastey substance that would indicate CRT coolant leakage. Let me know what you find.
Oct 24, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS 60601 picture
You need to change the convergence IC's my friend. If you know how to solder and work on printed circuit boards, this is an easy repair, BUT if you have no experience, play it safe and let a pro do this repair for you. Good Luck
Aug 11, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Green color lost
First thing to check my friend is bad connections on the green CRT board, or cannections on the green crt and the socket. If there are no bad connections on the board, but to tell you the truth there most likely is, as I have found this problem many many times in the past, you could take off the green crt board and swap it with one of the other board from the other two crts and the picturew will not be right, but this will tell you if the problem is on the green board or the green driver circuit. if the green continues to go out on this setup, then I would tend to believe that the green CRT is intermittant. Good Luck
Jun 07, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Televison & Video Logo
737 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
