Question about Mitsubishi WS-55807 TV
V chip codes
Need to reset V chip code. Accidentally set,
Did'nt bud... sorry but buypassing it did Q9 buttons at the same time did
Posted on Apr 21, 2008
  • 261 Answers
I think you hit "0000" then enter. I'm not positive but this maybe the answer. Give it a try and let me know if it worked. Thanks and happy tv'ing. Jay
Posted on Jan 31, 2008
Want to reset the v-chip on my 2001orion tv model # 1933
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Aug 12, 2012 | Televison & Video
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
Jul 15, 2012 | Televison & Video
Vchip reset? Inputs won't show HDMI input option. Floor model TV model# av-48P786 sn#13090154
If a power interruption occured to your household power supply, V-Chip has to be resetted. To reset the V-Chip do the following.
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
preset with a lock code of "0000". You may change the code to any four-digit number you wish.
To change the lock code, follow the steps below.
Press the MENU button
To SET LOCK CODE use UP/DOWN buttons.
To operate (lock icon appeares on pressing =>/ Press ZERO to access the lock code
The first digit will be highlighted
Use =>/<= button to
To select the number
Press Up/Down button to
To move to the next digit
Continue to follow these directions for all four numbers
Press the OK button to finish (your lock code is now set)
Press the Menu button when finished
OK. Thanks for using Fixya.
Apr 07, 2011 | JVC Televison & Video
A code was entered on my panasonic tv. i want to get the channel lock off can't remember the code.
There is one way to unlock your Panasonic TV. There is a procedure. Follow it and see whether your set can be unlocked or not. In most Pansonic sets this will work.
You must have its original remote control to do this effective.
Mar 23, 2011 | Televison & Video
V chip reset
i need to reset my sons v-chip how do i do that,he has a toshiba tv.
Sep 27, 2008 | RCA T20TF667 20 in. TV/VCR Combo
Default accidentally pressed and v-chip locked programming
What you want to do is contact Polaroid Customer Support and tell them the situation and they will give you a factory default code for the v-chip. The Polariod C.S. # is 1-800-605-5364. They should be able to help you without any problems. Hope this helps...
Jul 21, 2008 | Polaroid 3211TLXB 32 in. LCD Television
How to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Nov 12, 2007 | Disney DT1350-P 13" TV
V-chip reset
1) Hit [MENU]. Press [CH up / down] to select ?V-CHIP SET UP?, then hit [VOL up]. 2) Enter 4-digit access code with the Number buttons. If you have not set up your personal access code, enter 0000 (default access code).
Sep 14, 2007 | Emerson EWF2004 20" TV
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
