Question about Saitek A-250 Computer Speakers
Saitek A-250 My speakers work with other devices but wehn hooked up to the computer, I do not egt the sound. I can, however, pause a song playing on the computer as well as go to the next. Just no sound. Confusing.
  • predl Jan 21, 2008
    My other speakers that are hhooked up to my computer do work. The computer is even recognizing the Saitek A-250 system when it is hooked up. Just no sound coming from them. They do work when I hook the remote up to my i-Pod si I know they are working. I'm just missing a step and not sure what to do.
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello Predl
First things first
1) check speakers connector, size and if not go inside as supose, you may use from radio shack an expantion connector for those speakers to PC. other thant this, check for mute sound on PC.
good luck
Posted on Jan 21, 2008
  • Carlos L. Burgos
    Carlos L. Burgos Jan 21, 2008
    Hi again
    Well, another final step you can do is , go and see if you need a special program, that work for your saitek, but, I think is a problem with your speakers.
    did you got warranty for them? I suggest you use it.
I have a set of Saitek A250 Wireless speakers and a set of Logitech speakers. I can't get iTunes to play on the Saitek speakers, but Windows Media Player and normal Windows sounds do without issue....
click start control panel sounds and audio then select audio make sure the default player is the media you want to use as your default sounds also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
May 22, 2011 | Saitek A-250 Computer Speakers
I can not find the driver for my Saitek audio A-250. Can you help me on this problem?
fbsir idount no sorrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrry i dount no
May 15, 2011 | Saitek A-250 Computer Speakers
Is there a place where I can order a replacement Bluetooth USB/Button accessory for my Saitek A-250? The button seems to have died.
Unfortunately Saitek does not have spare parts for this product.
If you can find such button on ebay for example great, if not then you might have a chance of getting a replacement if the 2 years warranty is still valid.
Hope it helps...
Apr 04, 2011 | Saitek A-250 Computer Speakers
I have the saitek A-250 speaker system connected to my computer. I had them installed and used them for a long time. I don't know why but They do not come up as a choice in the control panel. I need to...
I've had this problem reoccurring for years. If I plug the dongle into one of the usb ports directly on the motherboard the computer will see the device.
Mar 18, 2011 | Saitek A-250 Computer Speakers
My Saitek A-250 speakers have been working very well for about 3 years and have suddenly stopped working. I have a Mac Mini 1.66GHz running OSX 10.6.6. The Saitek Speaker has vanished from the...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Mar 04, 2011 | Saitek A-250 Computer Speakers
Stopped connecting to PC
you might have to uninstall then reinstall both the drivers and the sound devices
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Jan 29, 2011 | Saitek A-250 Computer Speakers
Speakers stop working spontaneously
try and install the sound driver again this may help
Nov 21, 2008 | Audio Players & Recorders
Saitek a 250
hi! Efogarty
Happy Holidays
well, you need to install, the drivers, for your particular, SAITEK
then redetect the eq.
or restart your PC, when do the installation.
good luck
Dec 01, 2007 | Saitek A-250 Computer Speakers
Saitek A-250 Computer Speakers Logo
417 people viewed this question
Top Saitek Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Bill Boyd
Are you a Saitek Audio Player and Recorder Expert? Answer questions, earn points and help others
