Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Try plugging an external monitor to your laptop and see how it displays on it. It can be any kind of monitor even the old fat crt's as long as it has a vga cable that will connect to your laptops vga port.
If the display does not immediately show up, then you will have to hit the FN (Function key)+(F1 thru F12) to show the image. Press and Hold the FN key then hit the correct F1 thru F12 key. The correct F1 thru F12 key will have either CRT/LCD written on it or it will have a display icon on it.
If the image displays correctly on your external monitor, then you will need to replace your lcd screen.
there are a couple of conditions that could cause this. the first is If you had a second monitor plugged in then you would have toggled thru the mode using the function usually "fn+ f7 keys at the same time" to select the external monitor only mode. a simple toggle of these keys would flip it back. however it is most likely that you are having a screen issue. to test for this. plug in any standard VGA monitor (15 pin plug connector on the left, usually it's blue but on the Acer it is black in color)and again toggle the "function + f7 so as to try to get the external display to show that the system is up (it won't just find the display you have to toggle it to get it to energize). if this is successful and you see it on screen then you have a problem with the LCD screen/power/connector all internal items. hope this helps GL
Jammer
Please try resetting the Camera to the factory settings by pressing the reset button and check if it helps. If the issue persists, please try Power resetting the Camera. To Power reset the Camera, remove the batteries from it, then press and hold the Power button for 15 seconds. Now, reinsert the batteries in the Camera and check the functionality. If the issue still persists, then the Camera requires service. You can get the Camera serviced at the precision Camera service center in your area.
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory and then promise yourself to never use it again.
hi.. This screen shows areas of the photo that are overexposed slightly. It flashes them to help you. You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady. If you get any other screen in future you may have accidently pressed the arrow again. Just cycle thru the displays to get back to steady.
Sorry it took so long to get back to you with a answer to your question. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
I tried Solution #1 (twice) with no luck. But, when drilling down thru the options in "menu" I found one that said "reset" and tried that. Voila! Back in business. Display no longer blanks in 1-2 seconds. Don't know if this only works after reformatting internal memory or not. So, if no luck with "reset" try to reformat then reset.
