My hitachi 50EX16B is messed up
It has 3 bulbs gr red blue. i can adjust the red and blue throuth the menu but the green is turnerd counter clockwise a little. i can adjust the other 2 colours vet or horozontal but the green is turned. have pulled it apart but the only adjustments i can find r the ones to focus the lenses is there something i can do or do i have to call a techy?
  • pee_pa Apr 08, 2008
    Hi, My Hatachi projection TV, 53fdx20b, is giving duplicate pictures. Both Blue and Red convergence apear to be working fine. Green convergence is not adjustable. Screen has a green line that bows down about 3" down and off to the left. There is a double picture, mostly on the top of the screen, that is red and green with Green ghosting and red ghosting. You can see the red in the bowed area, and the red fills the screen as exspected. Any suggestions?
  • 8,617 Answers
Green is not adjustable only through the service menu. if the green yoke hasnt been turned then you most likely have a faulty capacitor or resistor in the green convergence circuits causeing the green projectors image to be skewed. without the service manual and some tv repair troubleshooting skills you will probaly need to call a tv tech
Posted on Jan 21, 2008
My Model TV # is 51swx20B. Two days ago the picture started having a lot of green in it and no blue. What is the repair needed.
Do adjustments on focus block. Will have to open front panel access door, focus block blue will be on left, green will be on top. Top screen bottom focus. Turn clockwise to increase, counter clockwise to decrease brightness. Turn the color all the way down on menu where it's pure black and white and make adjustments for perfect black and white picture, then when you adjust color, it will be perfect.
Aug 09, 2011 | Hitachi 51SWX20B 51" Rear Projection...
Sony kds-r60xbr2 televison
Make sure that you do not have a magnetichc feild around the TV.
Sep 06, 2008 | Sony KDS-R60XBR2 Television
Have a 46f500 hitachi projection television. Started out with a blue reversed arc hanging down on upper right. Now images are not focused, and red, blue and green are layered. Double images. I looked...
It is a convergence problem and set uses two of the STK-392-150 CHIPS. Both will have to be replaced and the set adjusted.
for more information let me know if you can solder and your skill levels.
SD TECH
Jan 11, 2011 | Hitachi 46F500 46" Rear Projection...
We got a free hitachi projection tv that i believe has a bulb malfunction. on the left half of the screen has a red shadow we cant afford a hundred dollars for an estimate then whatever the price of the...
You might need to adjust the red screen drive control, turn the Red down and see if that clears it out. Sounds like the Red Tube is over driving the Green and blue Tube.
Find the Focus and screen control block there will be 3 controls on Top 3 right under them R-G-B they adjust the Focus to each tube and screen drive for each tube. also you need to clean the lenses off top of each tube they get dirty and dusty and it would help to clean the mirror
Sep 13, 2010 | Hitachi 53FDX01B 53" Rear Projection...
I see red and green silhouettes of the images
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 53SWX10B 53" Rear Projection...
My hitachi tv's picture is distorted red and green like a 3-d pic
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 08, 2010 | Hitachi 57F710 TV
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Tv duplicate image
your guns are off and need to be adjusted. your 3 guns (red, green and blue) are off and that would explain the funny colors and shadows. Have a tv tech come out and have a look, they can fix it for a reasonable price.
Oct 20, 2008 | Televison & Video
My projection tv is srewed
The green has to be adjusted through the service menu. You may try moving the yoke ever so slightly, but if you do mark the position its in now so you can put it back if it doesnt help the green. You can adjust the horizontal and verticle skew through the service menue. but you probaly have a weak capacitor or open resistor that has caused your green to skew as that is controlled electronically.
Jan 20, 2008 | Televison & Video
Televison & Video Logo
191 people viewed this question
Top Televison & Video Experts
