Question about PNY Verto GeForce FX 5200, Graphic Card
Blank Monitor After installing a GeForce FX5200 in my machine, the monitor won't display anything. It doesn't matter whether I plug the monitor into the new graphics card connector or into the old, original connector. I boot up the computer and, voila, a blank screen. My machine specs seem to match the requirements on the FX5200 box. What can I do?
  • 1 more comment
  • jimkat Jan 21, 2008
    The FX5200 doesn't have an onboard fan.
    Dell PowerEdge SC420 Server.
    The problem isn't with the graphics card. I had installed new memory at the same time. I just removed the memory and the machine works fine.
    Anyone happen to know why installing two 1G, ECC DDR II memory modules would cause my screen to go blank?
  • jonathan Oct 12, 2012
    wait i have the same problem but what do i do? its extractly the same. so do i take out the ram ?
    Genius:
  • 1,067 Answers
Hey maby the onboard van on it dont work well with yoru pci slow ok so unplug the onbord fan try again ok
Posted on Jan 21, 2008
  • 1 more comment
  • nick helpap
    nick helpap Jan 21, 2008
    what computer u have
  • nick helpap
    ya ui need non ecc buddie eecc for server ram ok
  • nick helpap
    so it is s server ecc is good then but maby your mobo picky on ram u take u sure u can take ddr 2 also cheak timming for your dell edge
Where can I find a driver/adapter for Advent X19W LCD Monitor?
Goto device manager , uninstall the card. go into control panel and check that the driver is uninstalled from the programs list. Swich of the pc for a minute or two then reboot Windows updares does not download drivers for graphics cards so will not install or reinstall the driver that is causing the issue, 307? Users forget to uninstall from program manger in control panel which is why the card keeps reinstalling with the undesired driver.
Please let me know what happens
Dec 14, 2014 | Nvidia Computers & Internet
Second monitor detected but no signal?!
Try holding the function key ( fn) and pushing the F4 button. This very well may fix your problem.
Sep 22, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Dell s2209w with a GeForce fx5200 blinks black
Make sure your refresh rate is not set too high. for the 192N it should probably be not much higher than 60Hertz
Jul 31, 2009 | XFX GeForce FX 5200, Graphic Card
GeForce FX5200 into Sony Vaio Desktop - Disable onboard graphics
Check BIOS settings but first change the supervisor password and log in as administrator. In BIOS there is a option like IGP-PCI and vice-versa. Set it to begin with PCI, save and continue. This what generally what needs to be done when you are not using your inbuilt/integrated graphics thats incorporated in the MB.......sodeep
Mar 24, 2009 | XFX GeForce FX 5200, Graphic Card
I have just installed my geforce fx5200 and used it to watch films on the tv, using tv out. when i tryed to use my pc monitor, my monitor says no signal after loading screen..But it still works on my tv,...
Try going into the Display properties in the control panel or right click on the desktop and go to properties. Go to the settings tab and choose advanced, you should then have an Nvidia tab. Go to that and see which device is showing for the default display, you should see your computer monitor and you tv as choices.
Mar 11, 2009 | Nvidia Geforce FX 5200 Graphic Card
I have a Dell Dimensions 8300 with a GeForce FX5200 graphics card (version C.14.10.4502).It has D-Sub and DV1 outputs. The monitor is connected to the D-Sub output. However anything connected to the DV1...
Hey,
in windows, right click on your desktop, select properties, then settings and then click on the 2nd monitor, make sure the 2nd monitor is attached to the dvi, when the computer was turned on. so the 2nd monitor will appear in the settings.
this will give image from the dvi output. to get objects to the 2nd monitor drag them out of a corner of the first screen. debending on what side the monitor is at.
Let me know if you need anything elsed.
Thanks,
Ekse
Feb 18, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Multiple monitors with 2 Graphics cards
dude you got to use sli or cros fire but if just 1 monitor
Jan 23, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Screen blank
it sounds more like an error with the monitor more than the
g/card
can yo borrow a monitor for a few days to see if this remedy's the problem ?
Nov 12, 2007 | Nvidia GeForce FX 5200 Video Card Graphic
Dell monitor power down mode with Geforce GFX card install
I think maybe some how the main graphics for your pc has possibly switched to onboard. Try getting into bios F2 or DEl on boot up and highlight Advanced ChipsetFeatures and press Enter. In here make sure your AGP card is set as the Primary graphics controller. When done press ESC and 'Y' to save settings, then re-boot pc. Hope this gets you running again.
Nov 10, 2006 | Dell (M1325) (64 MB) Graphic Card
PNY Verto GeForce FX 5200, Graphic Card Logo
179 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
