Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Attachment problem used a new unit w/attachment for 5 minutes...dispensed solution in a powerful triangular fashion. Then the fluid quit dispensing out of the attachment nozle amost like the pump quit working. Primed the unit several times w/ no success. checked for clogs. can't tell if the floor portion is "pumping' or just dribbling solution onto the floor with the trigger. can see no leaks at this point. unit worked for about 5 minutes on apholstery
  • frustratednf Jan 22, 2008
    Fix Ya guys
    Thanks for the tips... tried them all .....Finally found a service center nearby,( most had quit doing hoovers!!!) The problem was a broken turbine!!! New out of the box yet!!! Go figure.....Tried it out as soon as I got home...now works like a dream. Thanks for all your help and promptly too!! What a great service you guys provide.
  • 397 Answers
Make sure everything is filled and secured tightly, if this a new unit it should be something simple ok, also check where machine folds down that the solution hose is not being pinched its right behind the dirty water tank
Posted on Jan 21, 2008
Bissell powersteamer won't dispense soap
Check to make sure the tank is installed completely. Turn off unit and unplug it. Then reinstall the tank, plug in the unit, wait one minute and turn it one. Check by using the sprayer. If that didn't work call the Consumer Care at 1-800-237-7691
Sep 24, 2014 | Bissell Powerclean Powerbrush Pet Carpet...
Why isn't the soap coming out of the despencer
Check dispenser seating, turn off unit, unplug unit. Reseat dispenser, plug in unit, turn unit on, wait one minute, press sprayer to test. While your at it clean the two filters. The filters need to be cleaned after each use. One is located under the Water Tank Cap and the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691
Jun 23, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover steam vac model 5853-900 has 5 brushes/cleaning dispensers, am only getting 2 small trickles of fluid when I dispense fluid onto carpet
The brushes come off, they are clipped on as an assembly if you look at the bottom of the machine you can see where the cover for the vacuum slot that brings up the water clips on too. If you remove that you can see the clips that hold the brush unit better
Feb 20, 2013 | Vacuums
Have a model 9200 that is not dispensing fluid,
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bnv,nm
Jul 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
We have an Emerson hands-free soap dispenser that won't work. We've installed brand new batteries and it still won't dispense soap. The red light comes on to indicate it' s working but no soap will come...
We have 5 Emerson hands-free soap dispensers that don't work. Tried new batteries, light comes on, but no soap comes out. How can we get our money back?
May 20, 2010 | Vacuums
When I am cleaning carpet, the water spray works
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 19, 2010 | Bissell 25A3 Upright Vacuum
I have a Bissell ProHeat Turbo. It has only been
i use white vinegar to clear my line.. and it doesn't hurt the carpet.
check the little filter on the top of the machine (mine is on the right side) if it is full of lint, etc and blocked it will not dispense or pick up.
Mar 28, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Soap/water solution pouring out on floor when trying to use hose & attachments
The attachment hose is torn right where it connects to the motor . And there should be a trigger on the end of the hose right below where it connects to the hand tool.
Oct 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Dispensing problem w/attachment and maybe floor partion
The F5914 has a hose that must be attached to the pump when using the upholstry attachment. Make sure that the solution hose is pushed onto the pump valve all the way. Try pushing the hose down and then pushing the locking collar down to secure it. This will insure that the hose is fully engaged.
Jan 21, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
100 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
