Question about Toshiba 19A26 19" TV
RCA T25061GY TV/VCR
Set has h.v. with no raster. On-screen displays appear when activated.
Also, no audio. Set has picture thru A/V jack and with VCR playback
but still no audio. Have replaced tuner module which didn't help.
  • 281 Answers
Replace the SAW Filter.
Posted on Jan 23, 2008
SOURCE:
How do I turn off pscan on a rca dro2oon DVD player
IMPORTANT:
If you don't have a Progressive Scan TV or you don't have the DVD player connected to the correct Input Jacks, and you activate Progressive Scan in the DVD player you won't see a picture! Don't panic-try the following:
First, press the PREV/VIDEO button on the front of the DVD player (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If that doesn't work, press and hold PREV/VIDEO button on the front of the DVD player for 3 seconds. Now, press the PREV/VIDEO button again (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If you still don't see a picture on your TV screen, make sure the yellow cable (provided) that is attached to white and red cable (called audio/video cables) is connected to the DVD player's PREV/VIDEO jack and the TV's Video Input jack. Change your TV channel to your TV's Video Input
channel that activates the TV's VIdeo Input jack where you have connected the yellow cable (page 9 of your manual has more information).This PREV/VIDEO jack on the DVD player always outputs interlace video, so you should see a picture on the TV screen.
As a last resort, you can reset the DVD player to the factory default settings:
Press and hold the STOP button on the remote control and the NEXT button on the front of the player at the same time - wait at least 5 seconds before you release both buttons
Sep 25, 2016 | RCA Televison & Video
Cannnot hear the music from video
you have not stated whether you want to hear the sound on TV or Stereo Receiver..
Here are 2 possible solution for both alternative..
1. thru TV
Your VCR has either 2x Audio (red and whitw ) and 1x Video output (yellow) RCA jacks or a SCART jack on the back side..
you need to connect all 3xRCA jacks to your TV's respective input.(or SCART ) than you will manage to see both video and hear the sound by selecting the VIDEO input on the TV .
2.thru RECEIVER
** you need to connect "Audio Output " RCA jacks of your VCR
** to "AUX input " or "DVD " OR "Any input" of your receiver ( except Phone )
** than just switch to respective mode on
RECEIVER corresponding your RCA connection...
There you go..VCR sound on the
Receiver..
*** pls remember you can connect VCR to either TV or Receiver to listen audio ,not both..the yellow RCA video output connection always goes to TV..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
How To Connect A VCR
your question is not clear enough. Do you mean "How to connect VCR to your TV?" If yes, then the below solution is the answer to your question. But if that's not your question, please rephrase your question for proper and accurate solution.
Connecting the VCR to a TV is not a big deal. There are two methods by which you can connect the VCR to our TV.
1. You can use a RF cord.
2. You can use a RCA cord.
I would suggest you use the RCA cord because the RCA connection has a better sound and display quality than the RF. So I would direct you on how to use the RCA connection method.
Here is a picture of what the RCA cord looks like for quick identification;
As you can see from the above picture that there are three cords. The Yellow cord is for display (video), while the with and red is for sound (audio Left & Right).
Turn of the VCR and the TV.
Look at the back of the VCR, connect the yellow to 'video out' and the white and red to 'audio out'. Note that the VCR might have only one audio out, that doesn't matter, just connect any of the red and white.
Now connect the other end of the cord to the back of the TV this way; Yellow will go to 'Video in' while the red & white will go to 'Audio in'.
Turn on the TV and VCR.
Select the TV to Source/AV and the display of the VCR should appear on the TV. Or better still, you can insert a cassette into the VCR, press play before selecting Source/AV on the TV.
By now the connection should be Okay.
If you any more questions or clarifications, please let me know as I would be glad to respond.....
Yours sincerely.
Elect_Comp.
May 26, 2011 | RCA Televison & Video
How do I connect a VCR with the TV
connecting the VCR to a TV is not a big deal. There are two methods by which you can connect the VCR to our TV.
Yours sincerely.
Elect_Comp.
May 24, 2011 | Sanyo Televison & Video
Hi my rca tv model l26wd23 screen light up but there is no sound are picture
No sound but has pictures? (no sound are picture ).
Let verify first to narrow down to where the problem can be. First, make sure the MUTE or SAP function is not activated, and then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Jan 05, 2011 | RCA L26WD23 TV
Ignorance on my part. Elect went out for hours; when came back on, no sound. Has something to do with onkyo and it's something simple. I've been thru this before; always seems to happen beginning of 3...
Hi and welcome to FixYa,
Initially, postback with the model numbers of the cable box, the DVD/VCR combo, the TV and the Onkyo. Additionally describe the plug/cable colors used form what jack of what device to which jacks of the next device.
Offhand, it would appear that the connection is basically output of one device is fed as the input of the following device. That being so, each of the devices (except the cable box) would have to be set for which of its inputs was used.
Good luck and thank you for asking FixYa. Merry Christmas.
Dec 25, 2009 | Onkyo Audio Players & Recorders
LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
May 25, 2009 | Rio Go Video DDV9475 Dual Deck VCR
How do I connect A STB to VCR to TV
connect the RCA jacks, audio ( red and white) and video(yellow) to the input on the vcr then hook another set of RCA jacks from the output of the vcr into the tv audio and video inputs
and thats it!
electech
Oct 20, 2008 | Televison & Video
Tv has no sound
U CAN BUY A VCR FOR ABOUT 10 BUCKS, AND GET BOOK SELF STEREO SYSTEM THAT HAS A SET OF AUDIO INPUT JACKS, USE A PAIR OF RCA JACKS TO CONNECT THE AUDIO OUT FROM THE VCR TO THE AUDIO IN OF THE BOOK SELF STEREO SYSTEM. NOW U SHOULD HAVE SOUND
Jul 21, 2008 | Durabrand DWT1304 13" TV
Rca projection tv has no picture or osd
Check the bulbs. If one is burned out, you will get this problem. The bulb is easy to change but will run you about $300.
Feb 10, 2008 | Televison & Video
Toshiba 19A26 19" TV Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
