Question about Dopod D810 Smartphone
BLUETOOTH! HELP HOW DO I TURN ON THE BLUETOOTH ON THIS PHONE?
My camera on D810 is not initializing .i have tried from camera button and from programmes also but all the time it says same message that unable to initialize the camera
Posted on Jan 02, 2010
Go to the start menu, and select Settings. Select Connections from the bottom tabs and find the Bluetooth icon, and click on the bluetooth icon. Select Mode from the bottom tabs and check box that says "turn bluettoth on"
Posted on Mar 05, 2008
Hi.i am having bluetooth problem with my nokia6120c. "unable to perform bluetooth operation" what to do&pls help.thanks.
Soft reset the phone. Disable the Bluetooth of the phone, then turn the phone off. Remove the battery for 5 mins. Then turn it back on.
Enable the Bluetooth, then try to search for another enabled Bluetooth device. Or simply try to pair it with another device.
If the same problem occur, then the Bluetooth driver could be corrupted. You may need to send the phone to the nearest Nokia Care Center and have them re-program or reload the Bluetooth driver.
Thank you and good luck!
Sep 20, 2010 | Nokia 6120 classic Cellular Phone
How can I connect jabra bluetooth to my cell phone
Generally speaking, bluetooth connects like this:
1:Turn on the bluetooth device (phone).
2: set phone to search for the bluetooth headset.
3: Turn on the headset
4: when it finds the headset (you may need to try TWICE), enter 0000 to the phone as a basic password. The two should link.
Your headset guide may specify a different password - use that.
The headset may require you to hold down a button to help the search - do what the manual says.
Apr 03, 2010 | Jabra Philips 768 / Fisio 820 / Fisio 825...
My bluetooth is not working in N73 mobile .When i turn on my bluetooth this error appears " unable to perform bluetooth operation " can some1 tell me why ?!
My Bluetooth is not working in N73 mobile .When i turn on my bluetooth this error msg appears " unable to perform bluetooth operation then plz help me someone
Mar 06, 2010 | Nokia N73 Cellular Phone
Bluetooth has lost connection with phone and I can't get it back
You should delete the headset from the "paired devices" list on the phone and completely redo the pairing process, it sounds like the two have gotten into some kind of wierd state.
If you need help with this please include the make and model of your phone.
Feb 09, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth problem on sgh-j700v.
Try removing the battery from the cell phone and removing the SIM while the phone is powered on. Reinstall the battery and SIM, power the phone on, and try to reactivate the bluetooth.
If that doesn't work, turn the bluetooth off and delete the device from the phone. Turn the bluetooth on and put in to pairing mode and re-pair the device with the phone.
If that doesnt work, one or the other is defective. If I've missed anything I've written an article that may help: http://yourmonstersofmobile.com/how_to_for_cell_phones/pairing_your_bluetooth.html
Aug 09, 2009 | Samsung J700 Cellular Phone
Nokia 6103 Bluetooth not turning on
just reload the software of your phone most probably it ll be fixed if not then u contact me again i ll give details of which hardware is defective
Jun 16, 2009 | Nokia 6103 Cellular Phone
Bluetooth pairing issue w/ jabra headset & Samsung SGH A-707
what you have to do is turn on the bluetooth of the other device and at the same time your phone's bluetooth is on. If your phone is the only device that the bluetooth is on near you then it your phone will not find a device. Cause your phone searches for another bluetooth device,therefore.....it doesn't include itself.
Sep 02, 2008 | Nokia 1600 Cellular Phone
Bluetooth headset
In the Connectivity menu, you can change your phone connectivity settings. You can turn Bluetooth™ and IR on or off, change the default mode for your phone when connected via USB hope this wrks..All the best
Happy to help
Have a nice day!
tc
May 30, 2008 | Sony Ericsson W850i Cellular Phone
BT350
try turning bluetooth off . first erase bluetooth connections on phone. turn off phone and take out phone's battery for ten seconds. put battery back in and turn on phone. plug bluetooth into charger for ten seconds and unplug it. try re-pairing bluetooth with phone. This worked for me!
Mar 06, 2008 | Jabra BT350 Wireless Headset
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Dopod D810 Smartphone Logo
99 people viewed this question
Top Dopod Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
