This is a simple network switch and it doesn't require any drivers. You just connect all the computers & other network devices to it using twisted pair LAN cables and that's it.
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Auto MDI/MDIX Crossover
All ports support auto-negotiating MDI/MDIX detection, which eliminates
the need for crossover cables or uplink ports. The DES-1016D is the
perfect choice for Plug-&-Play support for 10BASE-T and 100BASE-T
networks.
See -->> http://www.d-link.co.za/des-1016d.php for further specs.
MDI uplink port for easy expansion Expansion is easy through a MDI uplink port.
You cascade several switches together through this port to get more ports.
Auto-learning of network configuration
Flow control in full duplex mode for protection against data loss
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
connect the router configure the settings give by the internet provider and configure the NAT then u can attach a switch if required and can access....
Is this a brand new switch? Or did it come from somewhere else? It might have an IP address assigned to it that is interfering with the rest of your network.
Try plugging in a laptop only to the switch and give the laptop a static IP, see if you can access the configuration of the switch.
D'Link DES 1116D
