Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Freezer Shelves are too small for freezer and keep falling when I put food on them...
My GE SS Side-By-Side Refrigerator/Freezer combo is new. It's had this problem since the beginning when we moved into our new home. The freezer shelves and bin are just a little too small to fit properly. When food is loaded onto them the weight of the food causes the shelf to fall... I have called GE several times on this. They have TWICE sent out new shelves, but they fit exactly like the old ones and the shelves continue to fall when loaded with food. This is a very perplexing problem and one I can not figure out. My husband tried to "bend" the shelves out a little wider, but to no avail... Appreciate any suggestions!
  • 8 more comments
  • gailwalashek Jan 22, 2008
    I'm going to call GE to see if they have the oversize shelf kits. thanks for the advice.
    gail
  • PhilipW Feb 18, 2008
    I have the same problem with my Maytag side-by-side. Boy is it annoying. I tried bending them too, but they're too strong. I think if I put enough pressure on them, they'd break before they'd bend. I've tried contacting Maytag a couple of times, and mostly they don't seem to get what I'm saying, although I think I speak fairly clearly, and I don't think their support has been outsourced to India yet. Just airheads. Maybe they should outsource to India - they couldn't be as dense as the people I've been getting. All I can think of is to try to drill some holes in the side rails and screw on some rods. Seems like a lot of work for something that'll look like hell in the end.
  • Anonymous Feb 24, 2008
    I have the same problem with a Kenmore Elite upright freezer. I tool tried to bend the shelves out too. Doesn't work since I don't want to break them either. I can't figure this thing out and neither can Sears.
  • gailwalashek Jun 20, 2008
    Hi, this comment is for " the dr".
    Both times that GE sent out the new shelves they sent exactly the same sized shelves as what we already have in the freezer. GE does not seem to understand my problem and it's frustrating talking to them...
    I will take your advice and call to ask for the oversized shelf kits.
    Thank You for trying.
    This is so very strange, and especially now that I'm hearing from other people who have similar problems, and with different brand names/companies....???????????? What's going on here?????????
    thanks,
    gail
  • Anonymous Jul 29, 2008
    I just bought a brand new GE Adora Side by side and I have the same problem...the 2 wire shelves and one of the wire baskets are just small enough to fall through when weight is added...What the %#$*! Is the case to wide or are the shelves too small?
  • Anonymous Dec 26, 2008
    GE Profile PSW26P Stainless Steel Side by Side Refrigerator shelves don't fit
  • mindybbel Dec 27, 2008
    sounds like I have the same problem but it didn't start right away. Is it possible that the common wall between the freezer and the refrigerator is moving/bending causing the actual width of the freezer compartment to become wider?
    bottom line is that ge should have had this fixed by now. I want a solution other than cobbing something together.
  • dagolden Jan 24, 2009
    We have had the same problem with our side by side white refrigerator purchased from SEARS! They want a service charge fee of $75.00, will order the same factory supplied wire shelves for replacement. So what good is that, when the freezer temperature gets cold the side wall plastic cleats shrink and the wire selves fall, just like the World Trade Center collapsed, meaning no disrespect to the victims. I for one will never ever ever buy another GE Product knowingly. This condition is utterly ridiculous and GE quality control and engineering departments should be horrified at this design and the Company should hold their head low.
  • Tom Sheehan Jan 03, 2014
    It seems we all have that problem the walls of the fridge shrink and the shevelves dont fit any more. Must be a design feature. Just call them and tell them you will be contacting a lawyer about a class action because we have it on our unit also.
    We have the same problem
I had the same problem with the freezer sheles being too small in my GE Profile side by side. The shelves would simply collapse down with any weight on them.
After measurng the gap, I determined that the shelves were approximately 7/16" too narrow.
The fix I did was simple, effective, and very cheap.
I bought a roll of clear flexible polyethylene tubing at Lowes for about $5.The tubing is 3/8" outer diameter, 1/4" inner diameter (see picture below).
I cut pieces to fit along the side rails of the shelf, and then sliced the tube pieces down their length with a utility knife. I wrapped the pieces around the outside rails on each side of the shelf. It took a little work, but I got the tube pieces attached.
In a few spots, I did a double wrap of tubing.
The shelves fit tightly now and can hold significant weight without collapsing. Plus, they don't look too bad.
I hope GE fixes this simple problem in the future.
Freezer Shelves are too small for freezer and keep - 2_29_2012_2_35_52_am.jpg2_29_2012_Freezer Shelves are too small for freezer and keep - 2_29_2012_2_36_33_am.jpg_mi2_29_2012_2_36_33_am.jpg2_29_2012_2_36_53_am.jpg
Posted on Feb 29, 2012
  • 5 more comments
  • dawndave175
    dawndave175 Jun 21, 2012
    Thank you so much for this tip. I had the same size tubing on hand from an old fish tank and did this fix in about 15 minutes. I have no collapsing at all now.
  • dawndave175
    Thank you for this tip! I had the same tubing on hand from an old fish tank and was able to do this fix in about 15 minutes. I used heavy duty scissors to cut with ease and have no problems with collapsing at all now.
  • Chuck La Rosa Sep 12, 2012
    Thanks James! I will go out and get tubing and try. It sure has been a pain with the freezer shelves droping on my GE Profile Side by Side.
  • Marion Carbone Moynihan
    Thank you sooo much, this has been bugging me for a long time, I fixed it this afternoon at the cost of $5. thank you, thank you, thank you!!!
    But they should fix it we all paid good money for the product
  • Ellie Monk
    Ellie Monk May 26, 2014
    Thank you so much for this simple remedy...it worked like a charm.
  • Anonymous Aug 02, 2018
    Agreed. Even 4 years later, this solution is tops!
So I did drill some little holes in the side rails of the shelves and screw on some little nylon spacers; it works quite nicely, doesn't look too bad, and wasn't that much of a pain to do. I still think it's rediculous that I had to do it, and that the morons at Maytag couldn't even understand what my problem was. I don't think we deserve to be the leaders of the free world anymore.
Posted on Oct 06, 2008
  • 447 Answers
Ge should have some oversize shelf kits available....If you have recieved the proper larger shelves and they still dont fit ........good question time to get creative
Posted on Jan 21, 2008
2 Suggested Answers
SOURCE: Freezer Shelves are too small for freezer and keep falling when I put food on them...
i put a piece of wood in the groove. the measuements were 12 3/4 by 4 inches. since i did this my shelve has not fallen off since. you will see on the sides two slides. (The plactic stickes out to slide shelf into.) i saw the groove in the middle of the slides of the freezer wall. i just cut a piece of wood to fit snuge across and about 4 inches in depth. i have had no problems since doing this.
Posted on Feb 01, 2009
Plastic door shelves fall out
Try small cable ties if they sit on pegs sticking out you can then cut the ties for removal.
Aug 26, 2014 | GE 21 cu ft Top-Freezer Refrigerator White...
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Hi, my GE refrigerator has ice developing on the rear wall of the freezer, and things in my crisper drawer are freezing solid,please help!!!!
Unplug refrig. Empty all food from freezer side and remove shelves from freezer. Remove back metal cover from inside freezer. Melt frost with a hair blower. Examine defrost heater at very bottom of the coils you defrosted. If heater coil inside glass tube is broken, replace defrost heater. (note: replacement may look different, but insturctions included with replacement address that) If heater is not broken, replace the small white pencil shapped sensor at the top of the cooling coils.
Dec 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer shelves in my ge Dss25KGRC side-by-side refrigerator/freezer keep falling down. It seems as though the shelves shrunk and no longer fit. Could it be that the freezer walls have gotten farther...
I had the same problem with my 3 year old GE Adora side by side. Call GE at 1800-386-1215. They were very helpful! They sent me all new shelves and drawers that were obviously wider because they fit perfect(only took a couple days)! Included in the shipment were spacers that I could of put on the ends just in case I needed more width. GE knows about the issue and is dealing with it on a case by case basis.
May 21, 2010 | Refrigerators
Freezer shelf issue, roller adjustment, Icemaker problems
There is not a recall per say on this issue but there is what's called a training bulletin.. The cabinet tends to spread out causing the shelves to fall out typically in the middle.Some models have wider shelves that will not fall out but also can not be pulled out due to the recess in the sides of the inside of the cabinet. The other fix is installing a little c clip on the sides of the trouble shelf in hopes that it will stop it from falling out. part # is WB4X174 and I have not had good results with them but it is a cheap fix. 2 per side are needed. Ge would have to be contacted to see if wider shelves are available but they are very expensive!
Mar 21, 2017 | GE Profile PSC25MSWSS Stainless Steel...
The freezer side not freezing just cool, the
Open freezer door, pull food off shelves on lower half of inside freezer and look if you have frost building up on the back wall of freezer. If you do then you have a defrost heater or thermostat possible gone bad.
Advise if you have frost build up and I will advise on how to check it.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer shelves fall
They are made for ease of installation but unfortunately, not stability. Slightly bend the sides outward, making the shelves slightly larger.
Feb 09, 2009 | GE GSS20IEP Side by Side Refrigerator
I did the tubing solution others mentionedand it worked great.. instead of the 1/2" OD 1/4" ID reinforced tubing. I bought Polyethylene tubing at 3/8" OD, 1/4" ID.
Cut the tubing into lengths that will fit between the rails, split with a utility knife down the whole length. Use a screw driver to force open the end and slip the tubing over the rail.
Pic attached shows the tubing cut along side and forced on to the rail along with a pic of the tag that was on the tubing in an inset. I bought a 25' roll because i was in a hurry and not paying attention. I did 2 shelves, needed something under 1' per side per shelf. so I used 4' total for the whole project.
Jan 20, 2009 | Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
3,096 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
BOYNISMO
