Question about Moultrie MFH-DGS-200 Digital Camera
White pictures, low battery life, few pictures
I put the camera out on Monday and return the following Monday and the battery life has gone from 99% to 41% with no pictures or very few pictures or pictures that are white.
  • Anonymous Jan 28, 2008
    takes no pictuers with tracks all around it. when it does take a picture it is usualy just a white blur. I have tried diffrent cards that work fine in my camera and have no sucess with my digital camera it used to take good pictures. It is two years old maybe that is all the life that can be expected I have even stood infront of it to take my own picture at 20 feet and have the same result
    Problem Solver:
  • 6 Answers
I have used these cameras for years and I too get the occasional white out. Never has been a major problem or one that happns over and over. The other posts might be able to help you with this. The battery issue can be a number of things. I have found that not all 6v batteries are the same. Some work great from day one and some **** the first time you use them. 1-2 years worth of use is all I usually get out them before thy start loosing charge too quick. The weather also plays a big part in how long they last. Always put them camera in some kind of shade and out of direct sunlight. The heat and sun seem to drain a battery faster than using the flash. I just relocated a camera a few weeks ago that I was only getting about 100 photos out of a charge and now that I have it in total shade I have been getting an average of 400 . I just pulled the disk this weekend and had 837 photos. Pay attention to your batteries and if one does not seem to work get rid of it and keep the camera in the shade and I bet you will have better luck
Posted on Nov 29, 2008
I had a similar problem...the daytime pictures were white but the night pictures were perfect. I corrected the problem by cleaning the flash sensor lens...the camera now works great!
Posted on Jul 06, 2008
I glued a small peice of plastic under the flash and above the camera lens to shade it from the flash when it goes off. I then only had 2 pictures out of 40 that showed a white picture. The plastic peice only sticks out about 1 inch and didn't affect the flash on the subject. I also drilled holes in the bottom and hooked up a 6 volt tractor battery to it this gave me over 1 month of battery life with another identical camera
Posted on Jan 30, 2008
Why does my camera feel hot and says batteries are too low to take pictures (when I put brand new batteries in the camera).
Are these rechargeable batteries or disposable?
The following link describes how to choose the right AA battery for your HP Camera.
Also this is the reason why your batteries say you are low (link is to the HP support page)
The battery gauge predicts the remaining battery life, based on the current rate of use. Since digital camera operations such as focusing and using the strobe use battery power at different rates, the battery gauge may seem inaccurate until it adjusts to the new rate of power use. In addition, after changing settings or replacing the batteries, sometimes the camera takes a few minutes to determine how much charge is remaining in a battery. During that time, the battery gauge may not be accurate."
Sep 20, 2011 | HP PhotoSmart M627 Digital Camera
Kodak EasyShare Z612 Shuts down after taking a few pictures.
Question : What batteries can I use in my digital camera, and how long do they last?
Battery life depends on how you use your camera, the type of batteries you select, and how you handle the batteries.
Your camera is compatible with: KODAK Li-Ion Rechargeable Battery KLIC-8000 and KODAK CRV3 Lithium Batteries: A non-rechargeable battery. (so your battery might be in need of a change)
Using Your Camera
Some features, such as reviewing pictures and using the flash, require more power than others. Follow these guidelines to get the best use of your batteries:
  • Limit the time your camera is in Review mode.
  • Limit your use of the flash.
  • Use the LCD Dimmer or Auto Power Off features, if available on your camera.
  • Transfer your pictures to your computer using a compatible power adapter, camera dock, printer dock, or memory card reader.
  • Check that the latest firmware is installed on your camera. See Software, Driver & Firmware Downloads.
Handling Your Batteries
  • Wipe the battery contacts with a clean, dry cloth before loading it in your camera.
  • When using your camera in temperatures below 41° F (5° C), carry spare batteries and keep them warm.
  • Do not discard cold batteries that do not work; they may be usable when they return to room temperature.
  • Do not allow batteries to touch metal objects, including coins. Otherwise, the batteries may short-circuit, discharge energy, become hot, or leak.
Dec 10, 2009 | Kodak EasyShare Z612 Digital Camera
Could you please tell me where too look for how much battery live i have left. I have checked menu but can't find where it is.
The battery life indicator is only visible for a few seconds when the camera is first turned on. I believe it is in the top-left-hand corner of the display. It should be a horizontal picture of a battery, which is a solid-white when fully charged, and clear (outlined only) when the battery is getting low. If you don't have any indicators on the screen, press the "display" button to activate the icons.
Sep 27, 2009 | Fuji FinePix A900 Digital Camera
Low Battery Indcator Flashes
You can check the status of your battery, including chargeble life remaining, in the Setup Menu. You need to have the CSM/Setup menu option to display Full menus, not Simple, in order to get battery status. So see if that battery status selection says you need to replace the battery.
Since you can shake the camera to get full battery, it's possible the battery contacts (on the battery or in the camera) are dirty, so check that.
If you do need a new battery, spend the few extra bucks to get a genuine Nikon EN-EL3e from a Nikon dealer. I have learned that many off-brand batteries do not properly implement a needed reserve, and "Genuine Nikon" batteries bought online from non-dealers are often counterfeit, just relabeled junk.
Mar 01, 2009 | Nikon D80 Digital Camera with 18-200mm...
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Low battery signal coming on with new batteries
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Feb 12, 2009 | Canon PowerShot A75 Digital Camera
I have error 99 in my camera canon 400d
Ifd the camera is only 3 months old - return it for replacement
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Batteries are Depleted
A camera rep told me that use about 2500mi (?) batteries instead of the 900 I was using otherwise the batteries will be depleted with just one picture. Digital cameras or any other digital piece of equipment needs the extra power. Make sure that your charger will charge the 2500 power ones fully.
Dec 17, 2007 | HP Photosmart M407 Digital Camera
Short or No Battery Life
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.
Hope its helpful to you
Oct 09, 2007 | Canon PowerShot S1 IS Digital Camera
No Power
the camera has high battery consumption like the following: "My one beef is the battery life. I have since read a couple of reviews that claim the 'low battery' indicator comes on too soon. If you're clicking like crazy and using the LCD screen, it will drop quite quickly. I tend to set up my shot with the viewfinder, use the screen to double check the framing then turn it off and shoot."
Sep 12, 2005 | Olympus Camedia D-540 Zoom Digital Camera
Moultrie MFH-DGS-200 Digital Camera Logo
155 people viewed this question
Top Moultrie Cameras Experts
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
