Question about SanDisk Sansa m240 MP3 Player
MY MP3 WON'T WORK!!!!HELP!!!!
WHEN I PUT MY MP3 IN THE COMPUTER IT DOESN'T DO ANYTHING NOT EVEN SAY IT'S NOT WORKING. WHEN I TURN IT ON WHEN I PUT A NEW BATTERY IN IT STILL WON'T WORK IT JUST PAUSES AT THE SANSA M240 1. 0GB PAGE AND WON'T LET ME GO TO TO THE MENU OR ANYTHING.
  • dian1 Jan 24, 2008
    This is my problem. I can't click on my removable disk, because the computer doesn't recognize anything. When I click on it, it tells me to insert something! The USB is already plugged in! HELP!
  • yuanyi Jan 24, 2008
    my sansa m240 had the same problem,just the welcome page,and can't be find by my computer.
  • 167 Answers
Go to my computer and select removable disc (thats your mp3 player) then click and drag songs to the music file in the removable disc icon. This is how my friend does it with most of his mp3 players.
Posted on Jan 21, 2008
MY SONY WALKMAN CANNOT BE OPENED, IT LIGHTS UP THEN TURNS OFF IMMEDIATELY
What do you mean "MY SONY WALKMAN CANNOT BE OPENED"? If you mean that you can't get to the battery, then you should look at the charging piece in the MP3. If it wiggles or moves in any way, then there is no way to fix it. I myself had that problem once, and it needs charged, but won't take a charge for some reason. I glued the piece in place with super glue which didn't help, and even put a drop of water on it to see if the electricity needed a material to carry it. That didn't work either. I gave up, as there are no screws, so you can't put it back together. I would suggest getting a new one, getting a new charger, or taking it to the store you bought it at. If that doesn't work, then bring it to RadioShack and ask for help. It's worth a try. Or, as I always add at the end, continue looking on the computer.
Jun 16, 2012 | Sony NWZ-E443 Digital Media Player
My speaker won't work even i have set in...i can't hear anything from mp3 and even real media also can't be played.
Reinstall the sound driver and download multimedia player in the net, it's free!
Hope that helps!
Dec 20, 2011 | Computers & Internet
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
I recently bought a Scosche Digital FM Transmitter Model FMTD8/FMTD8R. I loaded my 8GB San-disk flash drive with music but the transmitter won't read it.. doesn't even detect the flash drive being...
wma files won't be read, only mp3 files, in my experience. My 512 mb SD card works, but it won't read my 8 gb SDHC card. I suspect it can't manage SDHC (high capacity) cards. I haven't tested yet, because as it turns out, neither can my computer... I think I'll fall back to a flash drive.
Jun 11, 2011 | GPS
My computer doesn`t see my mp3
Comment by vickisanchez, posted on Mar 19, 2008 IT FINALLY WORKS !!!!
Sandisk Tech support had me do the following:
- Turn it OFF
- Put it in the HOLD position
- HOLD the center button IN while plugging into USB port, continue to hold for 5 to 7 sec even after plugged in.
At this point MY COMPUTER recognized it. And it worked.
He also had me to:
- go to WWW.MICROSOFT.COM
- In the upper right hand search bar, type in MTP PORTING KIT
I did this and downloaded the first one. Now my Sansa Clip work perfect. I wish I would have talked to him last week before I returned the last one, for the same reasons.
If this does not help call the 1-800 # , opt #4, and ask for GUY (yes that is really his name) out of 5 or so calls to Tech Support he is the only one who knew what he was doing, and how to actually HELP.
GOOD LUCK
Mar 31, 2008 | SanDisk Sansa Clip MP3 Player
My Sansa doesn´t work well,
If it is still on, hold down the power button for about 15 seconds; that should turn it off. Try turning it on again. If it still does not work, turn it off by holding power for 15 seconds, then on again like this: - Put hold on - Hold record - Press power on This will start recovery mode, follow on-screen instructions. Hope all goes well!!
Apr 29, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
66 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
