Problem for Standard Televisions
Generic problem for all Standard Televisions
T.v. keeps blowing a fuse
we had a bad storm. after the storm tv didnt work.i replaced fuse and plugged it in and it blew the fuse again.
Comments:
Jan 21, 2008
- it is a magnavox model #27ms3404/17Jan 21, 2008
- as soon as you plug it inJan 21, 2008
- i am an electrician.construction,but i do have some experience in hme repares and fixing some electronics.would thes ittems be tested with a fluxe meter.what would they read a dead short with a continuety meter.i realy would like to fix this myself.i can solder also.
Best Solution
posted on Jan 21, 2008
Rank: Guru
Expert
Rating: 89%, 3846 votes
The storm probaly blew your horizontal output or one of the Diodes in the brdge rectifier. Hows your soldering skills and what model set do you have?
Comments:
Jan 21, 2008
- Do you hear anything when you plug it in? Does the fuse blow as soon as you plug it in or not untill you hit power.?Jan 21, 2008
- You have a dead short. Let me try to pull up your service manual and see if I can figure out whats happening in your set. I work at another site and we should have your service information. Give me a little bit and I will get back to you.Jan 21, 2008
- Okay your set has a phillips chassis Lo1.1UAC you must ahve a blown diode. There are four of them right next to whereb the power ccomes into the power supply circuit or the line transformer is shorted or the voltage regulator or horizontal output transistor. any one of those items shorted woul cause your fuse to blow as soon as pluged in cause you have part of the chassis that has live voltage even when the set is turned off ( standby voltage) Hope this helps.Jan 21, 2008
- Yes you can test the diodes and transistors with a regualar ohms meter. Diodes will test good if they allow continuity one way and block it the other way. And transistors can be checked the same way should show resistance one way not the other by reversing leads on the meter. Say if a transistoer shows full continuity no matter how you reverse the leads on the ohms meter you know that trans is shorted .Also if you need a service manual for your set let me know as the other site I work for sells it for 10.99 and they offer free unlimited support and will even email the manual to you. Just let me know if I can help you further. Just be careful around any capacitors cause they hold their charge and they can shock you.
Was this helpful?1 person thought this was helpful
Solution #2
Rank: Master
Rating: 79%, 172 votes
have you tried calling the tv manufacturer yet?
Popular Solutions for Standard Televisions
Sony FD Trinitron WEGA KV-32FS120 32" TV
1 Solution
Sony FD Trinitron WEGA KV-36FS120 36" TV
1 Solution
Questions and Unsolved Problems for Standard Televisions
Lost remote for Sanyo model # DS13204 and need to know how to put in video mode to watch dvds.
i need to reset my tv remote but dont remember the 3 digit code for a sanyo tv
i cannot make my foxtel connect to my c television correctly. picture rolls
my vintage sony trinitron KV2645RS is now mostly green w/ purple ´- what is wrong and do...
(More)
my vintage sony trinitron KV2645RS is now mostly green w/ purple ´- what is wrong and do parts still exist ?
why do some channels not have sound rca tru flat 27f522t
