Question about iLO DVDR05 DVD Recorder
Clock is faster than should be
Clock gains seconds each day
I have the same problem. Don't try using the auto clock update from antenna/cable either, that always sets it way off, if it even works at all I just keep setting it back manually. But now my unit has more major problems. It won't record anymore, its time to buy a better box.
Posted on Jan 24, 2008
How do I adjust my mantel clock so that it doesn't gain time every day.
American mantel clocks will gain or loose 5 minutes in a week, that is considered normal. This article will help you to adjust your time using the pendulum.
http://usedclockparts.com/9-clock-case-repairs/31-how-to-speed-up-or-slow-down-your-clock-using-it-s-pendulum
Dec 09, 2016 | Home
Cloc gains time
well without the make and model number I can only answer generally , most clock radios use the power line to sync the time base (60 hertz=60 seconds = 1 minute=60 minutes=1 hour) , but they use a internal time base generator when running on battery back-up (that's not so accurate) , I had one some time back that a customer plugged into a switched outlet (unknown to them) in there room and it did exactly the same thing it gained about seven minutes every day , me id check the outlet its plugged into to see if its on all the time (a quick test 4 this is to remove battery back up ) clock will then flash to be reset if you come back later to see it when the power was shut off
Jul 26, 2016 | Audio Players & Recorders
Nowhere in the little operations manual that came with my watch does it give the accuracy of the timepiece. Where can I get that information? I have a movado ESQ bracer chronograph.
Interesting question. I know little about watches but, as you would know, your watch does have a quartz movement, so, from Wikipedia, 'Quartz clock':
Standard-quality resonators of this type are warranted to have a long-term accuracy of about 6 parts per million at 31 degrees C (87.8 F): that is, a typical quartz wristwatch will gain or lose 15 seconds per 30 days (within a normal temperature range of 5 deg C / 41 F to 35 deg C / 95 F) or less than a half second clock drift per day when worn near the body.
If a quartz wristwatch is "rated" by measuring its timekeeping characteristics against an atomic clock's time broadcast, to determine how much time the watch gains or loses per day, and adjustments are made to the circuitry to "regulate" the timekeeping, then the corrected time will easily be accurate within 10 seconds per year. This is more than adequate to perform celestial navigation.
Assuming that you have a computer with internet-synced time and good internet, meaning around 1/100 second accuracy, why not compare the watch to the computer over the space of a week?
Sep 04, 2012 | Movado ESQ by Movado BRACER stainless...
Two clocks are set at 6am one clock gains 30 seconds every hour and the second clock loses 1 minute every hour. at what time will the faster clock be 30 minutes ahead of the second clock
Compute the difference in clock-speeds, namely 90 seconds per hour.
Convert the units of time: 30 minutes becomes 180 seconds.
So, divide 180 by 90 to get '2', namely 2 hours after the 6 o'clock "start" time, which makes it 8 PM.
P.S. There is at least one error in the above solution. If you truly understand the solution, make the necessary correction, and submit the corrected "homework" to your teacher.
Jan 07, 2010 | M2K Garfield: It's All About Math Math...
My clock is gaining time that is it is gaining about 10 minuts a day. what do I need to do
well if that is an electronic clock this problem might be because of the fact that these clocks use electronic timing circuit which consists of capacitors and resistors which are used to maintain a constant current flow to the timing circuit and if this RC(resistor, Capacitor) combination has some issues the circuit will not function exactly it is meant for and you will either get gain or loss of minutes.
so it is best to see if you can figure it out or just switch the clock.
Jan 06, 2010 | Emerson (B0002HKS0S) Clock Radio
Clock gains 5 minutes or more time over 30-45 days
Could be low-grade electronic components used, less than 1% tolerance values, or the crystal time-base, a precise clock-pulse generator, needs calibration.
Recommend to get it checked by electronics wizard.
Jan 31, 2018 | Aiwa FR-CD1500 Clock Radio
Bose Wave Radio CD clock gaining two hours a day.
I have the opposite problem (110v radio but 220v power). Like to exchange the power supply?
Nov 13, 2006 | Bose Wave Radio
Time keeping
Did you use the same batteries? try to use new ones... sorry i can't help you more
Nov 30, 2005 | RCA RP3710 Clock Radio
iLO DVDR05 DVD Recorder Logo
63 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
