Epson STYLUS CX3900 All-In-One InkJet Printer Logo
Posted on Jan 21, 2008
EpsonCX3900 NOT SCANNING TEXT AND SAVING AS TEXT IN Vista
I am trying to scan a page of text and save it as text but all I can save as is either PDF or an image. I just wish to save the text to convert to HTML for a webpage without having to type the lot out.Any one know whats wrong?
  • fremo Jan 31, 2008
    Thank you,
  • fremo Feb 27, 2008
    Ended up buying a copy of omnipage. Trouble was my first ever printer I think it was an hp 610 converted to text with its own ocr and just presumed evry other scanner did as well, hence my confusion. Thanks to those that replied.
Anonymous
Level 1:
Scholar:
  • Contributor 35 Answers
  • Posted on Jan 28, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
35
Questions
0
Helped
16355
Points
71
There is absolutely nothing wrong with either your system or the scanner device, its just quite normal the scanned document are often saved in PDF or a image file formats, All you need is a text converter software (OCR) through which you can convert the scanned image or PDF file to text document and the best part is that you can even edit the text of the scanned document and make changes if you would like to as well. Here is the link for the text converter software download.
http://www.charactell.com/scanstore/InstSocr.exe
Click on the link to download and install the software that you require.
Alternatively you can also copy and paste the link in your web b browser address bar and hit the enter key to start downloading wizard.
Regards
Malik Khan
A
Anonymous
Every time I scan a multiple-page document into a PDF file using my HP LaserJet M1319fMFP, in creates a separate file -- or document -- for each page, rather than simply scanning all the pages into a...
There is no easy way of doing this.
What you can do is scan each page as an image file, then use an OCR program to convert each page into a text file and save them. Then open a fresh/new Word document, then open each text file page and copy and paste each text file page into this Word document.
After you have copied all the pages into this Word document, then spell check it, edit and format the text then save the document. You can then create a PDF file from this Word document if you need to.
2answers
Want to scan several pages as one pdf document
Try OCR Terminal,which is an online OCR service that converts scanned images into searchable text. Register an account and you can convert 20 pages for free every month.
Have a try and hope it helps.
Seperates the pictures from the text when scanning
Stop scanning as an OCR. Scan as a PDF or photo and it will scan it exactly as it was on the scanbed.
When scanning for OCR OPTICAL CHARACTER RECOGNITION it is translating the text for notepad and saving the pictures at the end or in separate files.
When scanning, the scanned page is not readable from a third of the page down to two thirds of the page.
It is important that the item you scan comes in close contact with the scanner glass. If the resulting scanned image is not clear, check to see that the item is in full contact with the scanner glass. The scanner uses optical character recognition (OCR) to convert text on a page to text that you can edit on your computer.
  • If you scan text but cannot edit it, make sure that you make the following selections during scanning:
  • Scanned text might not appear on your computer exactly as it appeared on the original, especially if the original contains faint or smudged text. For example, some characters might be incorrect or missing. As you edit the text, compare the scanned text against the original, and then make corrections as necessary.
  • To change text scanning options, click the Scan Document Settings button in the initial What are you scanning? screen.
  • The OCR software is installed by default when you install the HP Scanning software during scanner setup. If you use the Custom option when installing the software, you can choose not to install the OCR software. Try reinstalling the software using the default install options.
  • Email to [email protected]
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
HP 5610 scanner won't save image
I just need to understand the exact issue. It sounds like you are able to successfully scan, see the preview of the scanned image, and you initially save it. Then, when you go to open the saved image, you don't see the image you scanned but rather a "line". You've saved the image in a number of different image formats, but there's no difference in the result. It saves the scanned image to the location you want to save it on your computer's hard drive (probably My Pictures if you're using a Windows operating system).
Not sure what you mean by a "line". Do you mean a vertical line, a horizontal line, a diagonal line or what? Also, is it just a solid black line on a white background? Is it the image you scanned compressed into a smaller vertical or horizontal space?
Have to tried scanning both text pages and graphic pages? There have been issues where a document with both text and pictures has been scanned but when the scanned image is viewed, only the text appears. The pictures don't make it. The description of this specific problem is at HP.com.
I take it you don't get any sort of error message associated with this problem. Unfortunately, I can't find your specific problem at HP.com beyond the link I posted in the above paragraph. If you can answer some of the questions I asked, it might help me provide a better solution.
Thanks.
Scanning Problems
I would first make sure that you have latest driver update. MS Word is very particular about how it reads things back in. I would try saving the scan as a text file or PDF instead and then open them in Word. Hope this helps!
If this solution was helpful to you, will you please rate the solution? Thanks!
Scanning a document
Hi
Easiest way...
1. Choose SCAN
2. Then SAVE AS *remember where you saved file.
3. On the FORMAT options when saving choose "JPEG"
4. Open your email and choose ATTATCH A FILE
5. Choose FILE from where you saved it
6. Add your text to email and click send email.
7. If you want to check FILE was sent
8. Click on Email SENT you should see it.
Good Luck let me know if it solved it for you !
Thanks
Tinteiros (Ebay)
Scanning problem to .pdf
Have you tried FoxIt Reader?
plz re install adob but before that plz un stall it from the control panel
Scan and Edit
i believe this is called OCR scanning, character recognition so that the text can be edited in text editors. I have not used works to know if it has a text capture feature but I'm aware of scanning software that offer OCR capabilities, i used to have that on my old scanner, i do not remember the name of the software but here's what google turned up for OCR scanning:
http://www.google.ca/search?q=OCR+scanning&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
second link shows free OCR Tools
HTH
Marc
2answers
Scanner
are you pressing ok on the printer? all of your scanning should be done via the MP460 navigator. check your applications under the Canon Utlitiy and click on the MP460 Navigator button. scanning needs to be done via that - not the actual printer. refer to the dialogue box when you are on the MP460 navigator. lower left area has a Save bar, when you click on it tow options: save to PC or save as PDF.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
