Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Clogged hose by the brush roll
The hose on the bottom of my vaccum by the brush roll repeatedly gets clogged. The brush roll will pick up dirt, but it just remains there and cannot get up through the hose no matter how many times I unclog it. Is it a problem with he motor or having enough power to get it through the hose?
  • Anonymous Mar 14, 2014
    need to unclog brush roll
  • 397 Answers
Sometimes there maybe something interfereing with it getting clogged up repeatedly, etc....needle, paperclip....be sure to check to make sure nothing is interefering with the flow....i have seen this many times.....suction can be a problem from the motor but your motor will be noisey
Posted on Jan 21, 2008
  • Custom Exchange
    Custom Exchange Jan 21, 2008
    if it was the motor you would know, did you purchase the machine new, if so it might be filters, if not it could be seals not giving appropriate suction
How to replace vacum belt on new Sharp EC-TU5306
remove bottom plate and pull brush roll out. buy a replacement belt and follow procedure to put back on. sounds like you have a clogged hose also.
Jan 29, 2013 | Sharp EC-TU5306 Bagged Upright Vacuum
Brush doesn't spin and there is no suction there either, the brushes move freely when manipulated manually
Check for clog in the hose or what ever connects the nozzel to the collection device. I pick up vaccum cleaners all summer, most new, all clogged, all from the trash.
If possible, take the machine outside, open the collection device, run the motor. Is there suction you can detect anywhere?
Sep 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Motor runs fine and hose not clogged will not pickup dirt
This may sound silly, but have you checked the belt? A lot of Eureka vacuums use the vac motor to run the brush, and if the brush is not running the vacuum won't pick up. Another thing to check is the condition of the fan blades.. if they get worn they will push air out of the exhaust ports, but not push enough air to pull the dirt into the vacuum bag. Another thing to check is the length of the bristles on the brush... you can change a lot of the bristle strips and save the cost of a whole brush roll.. All of these fixes are under $10.00 (Belt: $1-2, Brush Strip $3-6, Fan $5-10) at most places.
Jan 19, 2009 | Eureka Vacuums
My Eureka vacuum model 4471 does not pick up - the bag is new??
Check to see if the hose and the dirt inlet by the brush roll is open and not clogged. Also if you haven't replaced the belt in a awhile, it may have stretch to the point that it isn't turning the brush roll under load.
Aug 10, 2008 | Eureka Vacuums
When the vaccum is running the motor gets hot & smells & is very noisy.
Sounds like yu may have a clog, either in the inlet by the brush roll, or the hose. If the hose comes loose, see if there is suction there. If no suction then it is clogged. If suction, then the inlet maybe clogged.
Jul 22, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
My eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Jun 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Dirt devil 12amp,Patent No.6571425
Either it needs a new belt, they stretch and break, then won't turn the brush roll. The dirt inlet by the brush roll is clogged, the hose may have a clog in it, filters are bad. If the hose comes off on one end, is there suction there, is so then the clog is farther down. If no suction, then the clog is in the hose or filter.
Mar 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
No suction
Fiflters should be replaced at least once a year, they go bad. You could also have a clog in the hose, or the dirt inlet by the brush roll may be clogged. Take the hose off if you can, drop something down it and see if it comes out the other end, if not, then it is clogged. Dirt inlet, you have to remove the bottom plate for one end, the other end is where the hose plugs into. Check it for a clog.
Feb 19, 2008 | Dirt Devil Featherlite Bagless Vacuum...
Dirt devil dual cyclonic bagless vaccum
Did you check the hose and the inlet by the brush roll for a clog?
Feb 16, 2008 | Vacuums
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
75 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
