Question about Frigidaire GLTF2940ES Front Load Washer
Will not unlock.
My washer door will not unlock. i turn it off and attempt a wash cycle, but it will only buzz and and then display a code dr. What can i do
  • 1,294 Answers
Try pressing 'end of cycle'; wait for 2 minutes or after hearing a click to open the door.
Posted on Jan 21, 2008
Why is my washer displaying a "DR" when I push start?
  • 1 Press any button on the display panel.
  • 2 Wait five seconds and then press and hold the "Start/Pause" button and the "Cancel" button at the same time.
  • 3 Open and shut the door. A "DR" error code indicates that there is a problem with the door, most likely that it has not shut properly. Check to make sure there are no clothes or other items caught in the door.
  • 4 Open the door and gently wiggle the door latch if the door does not click shut. Clean it with a damp cloth to remove excess dirt or debris that may prevent the door from latching into position.
  • 5 Close the door and re-select a new wash cycle and "Start."
  • Jul 25, 2014 | Frigidaire Affinity ATF6000F Front Load...
    I have Frigidaire Affinity ATF7000EGO washer. i just replaced the door striker but now everytime it goes to start cycle starts buzzing and reads DR....
    Double check that the mechanism is fitted correctly and all wires are attached as off the top of my head that is the error code for the door not sealed properly. Hope this helps.
    Nov 17, 2013 | Washing Machines
    Error code " du "
    DU = Door Unlock code
    Washing machine displays error code F/DU after six attempts to unlock.
    -Door lock assembly failed.
    -Test door lock switch
    -Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
    The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
    Hope this helps.
    Jun 22, 2011 | Washing Machines
    If you get the FL how do you get the door to open??
    1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
    2. Do
    3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
    4. FL
    5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
    6. Sd
    7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
    8. PF
    9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
    10. Nd
    11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
    12. LO
    13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
    14. Lr
    15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
    Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
    What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
    "F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
    In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
    Thank you !!
    Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Says "dr", will not start
    The error clearly indicates bad door switch. Very simple to fix, have to take top off and loosen switch from front panel. Remove and replace.
    Part #131763245 and suggested retail price $50.
    Thank you
    Jun 14, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
    I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
    dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
    Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
    After a load it makes a sound and as if the door
    your lock could be bad, but when it unlocks it buzzes as if already unlocked? Is the door actully unlocked during the cycle but display reports locked? this would be a bad switch within the lock asm
    Jul 14, 2009 | GE Energy Star WCVH6260F Front Load Washer
    Washer problems.
    some of those pumps had a small hose going to it from the water level control have had trash pulg them up on pump end and at pump port ck it ..if pluged control may thing washer has enough water and will not let any in also pump may have gone kaflooey
    Sep 16, 2008 | Maytag Neptune MAH9700 Front Load Washer
    Kenmore elite HE 3t - error code F dU and door is locked
    Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
    Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
    Frigidaire GLTF2940ES Front Load Washer Logo
    87 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
