Question about Dacor ECS130 Epicure Electric Single Oven
Delayed auto start
When we try to program theoven to start automatically later in the afternoon while we are at work so dinner ill be ready when we get home, the fan starts immediately.
Can someone please give us a list of the exact sequence of programming steps to set temperature and start and stop times so this feature will work.
THank you in advance.
Stephanie Wolverton
stephanie_ssi@bellsouth.net
    Scholar:
  • 196 Answers
In some units this is a normal function. Wait for about five minutes and see if the fan turns off. If not, please let me know and I'll find a solution for you.
Posted on Jan 26, 2008
How do i fix the timer for delayed start
Strangely in all of this, u don't tell the oven when to start - it works it out itself!
First u need to set the length of cooking time, eg 2hrs.
Press the cooktime button(2nd one along), THEN use the +/- buttons to set the display to 2.00.
THEN press the readytime button (3rd one), and use the +/- buttons to set the end time.eg 1730hrs
The display should then revert to the present time.
THEN turn the oven control to the required temperature.
The oven will switch on at 1530 hrs.
If u were to press the cooktime button ONCE WHILST the oven was on - it will display the cooktime remaining.
AT 1730, the oven will switch off and the alarm will sound
To switch off the alarm, press the minuteminder button - first one - looks like a bell, THEN
REMEMBER to cancel the programme by pressing buttons 2 and 3 TOGETHER, otherwise it will do it again tomorrow!
HOPE THIS HELPS
I would suggest first.trying it when you're at home all the time the oven is on.
Sep 08, 2014 | Belling XOU592 / XOU593 Electric Double...
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
I have a stoves 720ef oven and cannot get rid of the auto
The handbook says:-
To cancel the automatic setting and return the oven to manual operation, press the cook time and ready time buttons simultaneously. These are the second and third buttons from the left. If you have done that and it is not working, try turning the complete oven off for awhile - say 30 mins and turning back on. If this still doesn't work then it may be that the timer/clock has gone faulty.
Nov 10, 2011 | Stoves 720EF Electric Double Oven
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
I'm in the middle of cooking dinner and I got a f3 e2 error and the oven locked...how do I get my dinner out? My husband is an elevator mechanic so he's handy...we turned off the breaker to quit...
That code refers to the oven temperature sensor sensing a too hot oven. I suspect what you did to quite the cleaning cycle should help once the temperature cools down the door should open. I am a little confused, did you set the oven to clean while your cooking, or did it do this on its own, or was it preset and yopu forgot it was set to clean? Your temp sensor may be going bad if it just detected a too hot oven while your cooking. If it started cleaning then it may have gotten too hot and this is the safety device to prevent it from overheating. it sounds like it is trying to self clean, its essential that you find the error code sheet, stuck in the stove or oven cabinet somewhere, also check your range settings so that it is not set to auto clean.
Jun 28, 2011 | Ovens
MICROWAVE OVEN HOW TO USE POWER LEVEL AND COOKING TIME. For example a want to cook pizza what will i use?
We probably need a little more info on your particular oven before suggesting what power levels and times. Do you know the wattage of it i.e 900w?
Does it have presets on it? Your manufacturer may have put auto programs on it to reheat, cook from frozen etc.
Final hint: If you are buying things such as frozen pizza, microwave dinners, the microwave instructions are usually on the box with a recommend time for a particular wattage oven.
May 04, 2011 | Ovens
I have a Fagor 5H 196X oven and whenever I set the automatic timer it cuts off after 3 seconds and the automatic shut down symbol appears does anyone have any ideas
Please find here our reply from the customer service of Fagor America:
This problem could be confusion over how to properly program an automatic cooking function. First, you must program the cooking duration, then you must program the time of day you want the food to be ready. Sometimes customers think they need to program a “start time” and an “end time” versus a “duration” and an “end time”. Please, make sure you are doing both steps correctly. Also, you should be aware that this clock works on the 24-hour principle (military time). I know that sometimes this confuses people as well. If both of those are okay, then it probably has a defective clock. If that is the case, please feel free to call our customer service:
UNITED STATES OF AMERICA and WESTERN CANADA: Please contact ADCO Customer Care at 1.877.743.2467, or by email at: fagor@adcoservice.com
EASTERN CANADA: Ontario, Quebec. Please contact A.G.I Service Inc: Telephone: 450-963-1303 or by email at: nruel@agintl.qc.ca.
If you have any other questions do not hesitate to contact us at: infoappliances@fagoramerica.com
Best Regards,
Aug 22, 2010 | Fagor 5HA-196 X Single Oven
How do I get theoven Miele h4900b childproof?
The old fashioned way, say NO DON'T TOUCH and move the child away.
Jan 08, 2010 | Miele H4900B Electric Single Oven
Dacor Electric Double Oven - bottom oven won't heat
If ti has a timer that is flashing auto, reset it to manual , as it will not work in auto mode.
Hope this helps.
Plz rate soltuioun.Thanks
Dec 26, 2008 | Ovens
Kenmore Elect Built-IN Oven Model 790
You don't say what specific F code error. If it is an F7, go to the following link for my solution.
http://www.fixya.com./howto/h155060-dreaded_f7_error
I have shared my fix with over 1570 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Feb 23, 2008 | Ovens
Dacor ECS130 Epicure Electric Single Oven Logo
143 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
