Question about Sony VAIO VGN-A150 Notebook
VAIO VGN-A150 motherboard
Hi VAIO experts,
After Sony replaced the motherboard twice for a display problem (meshed lines, green/red), the same problem returned last June. At first, the lines would go away if I applied pressure at a certain spot on the back. This only worked temporarily. Over school break, I discovered that just under the
bottom panel (which covers the memory chips), next to the screw hole, is what looks like a support post against the board. Directly underneath this post, a resistor labeled R1209 is now missing, and at closer look I noticed the fractures in the solder; it's apparent that the support post eventually broke off the resistor part. This post is obviously in a wrong place. I've emailed Sony about this, but they want me to send the laptop in and pay for another replacement.
I would really appreciate it if you tell me the value of R1209. I'd like to solder in a replacement resistor to see if I can fix the display. If it does, I will cut off the stupid post.
You would have to open up the memory access door at the center of the back panel and pop up the memory card, unless you happen to have a parts list or a motherboard on hand. Please help me.
  • 198 Answers
That would be verry difficult to find. A service diagram of this model is imposible to be found, at least over the internet. However here are some tips you may find usefull. If you have acces to a multimeter or at least a current-voltage measuring device, try to turn on the laptop and measure the voltage on those pins where the resistor is missing. If you find something smaller then 10 volts you can try the following method.
Buy a 1 mega ohm resistor along with other smaller values like 100kilo ohm, 10kilo ohm, 1 kilo ohm, 100ohms, 10 ohms. These resistors don't need to be smd tipe, regular ones are good at least for this testing stage as long as you can solder them on the motherboard. Begin by using the larger values (1 mega ohm) and check to see if the problem is solved or something is different. Then decrease step by step checking each time how the problem evolves. When you reach to 1 kilo ohm, don't solder the resistence like before, instead mount an amper-meter in series (not parralel !!! ) with the resistor. Check to see how much current is passing through the resistor. If you find more then 100mA stop here, because by following this metod down to smaller values of that resistor you may damage the board if the current exceeds certain levels.
Try this simple tests and please notify my of the results. You may ask further questions if you need more details on this matter.
Posted on Jan 21, 2008
Sony vaio vgnfz280e b
End users can at best expand memory or disks (hdd/SSD) on Notebooks from internal hardware perspective.
In my humble opinion, the motherboard of any brand laptop, notebook computer are highly integrated and the video is very much a part of it that cannot be replaced. At best you can try different video settings and perhaps even a different driver version if available.
May 14, 2017 | Computers & Internet
I have Sony Vaio VGN-FZ15G motherboard working but have no display
First step is to hook it to an external monitor. If the monitor has signal, then you should be able to re-seat the video cable on the system board. If not, then something internal, like the motherboard, is defective.
Nov 08, 2012 | Sony Vaio Vgn-fz15g / Vgn-fz15t /...
I have a vgn-a150 laptop, and am trying to hook it up to my hp flat screen tv. I tried a video connection to the tv's rca jacks, but nothing. So I tried to connect vga to vga, but still nothing. ...
try a coax or composite cable.make sure they are properly connected and check the settings on your laptop (display settings) depends on the computer's operating system
Jul 27, 2011 | Sony VAIO VGN-A150 Notebook
This is referenced to my Sony Vaio VGN-A150 Laptop. The flat cable connecting the touch key pad to the motherboard is broken. I need the part name, number & where to purchase. Thanks!
Did you ever found what was the part number and where to purchase? I am having the same issues and I cannot find it Either.
Nov 12, 2010 | Sony VAIO Notebook
Sony vaio vgn-a-150, doenst show screen, and i hear i clap clap, when the pc try to run but no.... just show 2 light in the front flashing
Remove battery, Power, memory, HDD and let the laptop for 6 hours.
Then connected the HDD>memory>Battery>power and try again,
Aug 14, 2009 | Sony VAIO VGN-A150 Notebook
I had a virus, my computer was formated. How can I get the recovery wizard of my VAIO VGN A150?
Formatted usually means everything erased, so the recovery software is gone, check sony website for recovery programs to download
Mar 24, 2009 | Sony VAIO VGN-A150 Notebook
How do I have access to the hard drive on my vaio VGN-a150
hi my frieed l saw your messange in box the only thing you can do is that you need the change , Just change it? later
Jul 24, 2008 | Sony VAIO VGN-A150 Notebook
Sony Vaio Laptop LCD pixulates
its a sony vaio right? does it have the latest video drivers installed? have you tried running dxdiag? try this ones first and see if there are errors found. if eveythings fine with the drivers and dxdiag. probable solution for the lcd is to replaced. check it out first and post your findings.
Jun 12, 2008 | Sony VAIO VGN-A150 Notebook
Sony VAIO VGN-A150 Notebook Logo
329 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
