Question about Dayton (3E379) Heater
Heater wont work
I have a Dayton kerosene turpedo heater model 3E218C - 100,000 BTU, which I purchased approximately 14 years ago and the problem is when I plug it in it will not ignite, I want to know where I can buy parts
  • Anonymous Feb 17, 2008
    clean the fuel filter with air . pull the fuel pick up hose out of the tank check if its good. blow out the fuel system with air. presureize the tank with a little air and plug in be careful . usualy blows flames for a while . good luck
  • 4 Answers
Dayton heaters. com?
14 years old? dayton still exist?
Stop trying to blow self up--go buy new one
Posted on Jan 21, 2008
How to ajust dayton 155000 btu torpedo heater when running smell like kerosen
You say: When running it smells like Kerosene--
That is what you are burning in it, right?
Is it smoking--- like there is a poor combustion mixture?
-- like maybe not enough air pressure?
There is a pressure adjustment for both-- Please check the manual for adjusting the pressures for your particular model.
Jan 18, 2011 | Dayton E50 Heater
Heater used once 3 yrs ago. Now wont start.
When the heater hums is the fan turning. If it is I would add more Kerosene. There is no shut off but the Kerosene is sucked out a tube from the top of the tank. This tube does not reach quite all the way to the bottom of the tank. Your heater should hold about 9 gallons if it is empty. A couple of gallons would give it plenty to run though. Let me know.
Jan 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
I need a rotor pump and blades for a dayton 150,000 btu heater model number 3e219c
Lots of time if you clean the blade area and remove the thick gunk from around the cover and housingand replceblades this should do the trick...
Dec 16, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Dayton Model 1VNX5 Kerosene clicks like crazy but won't light
I have the same heater with the same problem. I took the top cover off, removed the ignitor and bent the probes slightly closer. Use two needle nose to prevent breakage of the holder. It has been working fine since.
Dec 13, 2009 | Dayton Heating & Cooling
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Won't light/stay on
It may be the spark plug (or the ignition module). On my Reddy Heater 50K BTU, there are six metal screws that join the top of torpedo tube to the bottom. Remove these,and the top of the tube casing. The spark plug should be in plain sight.
Turn the unit on and look for spark. If it's not firing, replace the plug. If it still doesn't fire, you may need to replace the ignition module (it's what is "connected to the spark plug via the fat ignition wire.")
Hope this helps,
Jan 06, 2009 | Dayton E50 Heater
Dayton (3E379) Heater Logo
567 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
