Question about Denon AVR-1707 Receiver
Denon AVR-1707 Zone 2 no sound
Gentleperson,
I am having trouble setting the Zone 2 speakers. I have set the Amp for Zone 2 as per the owner's manual, have speakers connected and still am not getting any sound. I have the sam type receiver at home and had no trouble getting the Zone 2 to work. Any ideas?
  • Anonymous Jun 23, 2008
    I am having trouble setting the Zone 2 speakers. I have set the Amp for Zone 2 as per...
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
SOURCE: Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
Posted on Aug 06, 2008
SOURCE: Denon AVR-2105
If the Cd is wired digitally, it will only play through the main zone, because the Denon cannot convert down to RCA to cater for the zone 2. If you plug RCAs from Cd to Denon, Main zone will STILL play from digital, and RCA connection will allow zone 2 to play Cd from RCA input....same with dvd, Satellite Blah blah... no stress, any nasty RCA will do if you want to try before you splash out on really costly cables...perhaps you can help me...want to run AVR 2105 with 2 speakers in zone 2, manual says cant do it - only ably to surround back or biamp...dont want either, dont have stereo yet to try it out...did you have any trouble with that?
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Posted on Jan 01, 2009
If no sound coming through Zone 2, steps that worked are below. Layout: Denon AVR-988 running in 5.1 mode with patio speakers designated as Zone 2: 1) check that patio speaker wires are connected to Denon's back surround speaker terminals, 2) check "Menu then "Manual Setup" and scroll to check that "Amp Assign function is set to "Zone 2". You won't get Zone 2 sound unless this is chosen in this instance. Also check the volume settings in the "Manual Setup" to ensure you haven't turned sound down by -40 DB or limited it. Now try turing on Zone 2 sound either on front panel or on rear of remote. If you still have no sound, what worked for me is there's a Zone 2/Rec Out pushbutton on front left top panel by round input knob. This must be set to "Zone 2 Source" and not "Rec Out Source".to avoid diverting the signal to the Rec Out jacks. Keep turning the input select button until it reads "Zone 2 Source". Then turn on and this should route the signal to your Zone 2 speakers. srhfish
Posted on Mar 04, 2009
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
I have a Denon AVR-1707 with a center, 2 front speakers, and surround sound back speakers. When set to FM radio, all speakers work. When set to TV, only one side speaker works. Any ideas? It worked fine...
Follow the sound back to its source. FM is internal so it can't possibly have a cabling issue.
I imagine your TV sound ultimately originates from a cable box which has a nice juicy digital output that the Denon could use. Why route audio through a TV, like the manuals tell you, when you can get it straight to the best audio device without a detour to a TV and its dubious audio electronics?
Apr 17, 2011 | Denon AVR-1707 Receiver
Trying to hook my lg tv to a denon avr-1707 receiver so i can have external speakers
Use the twin phono audio out on tv to twin phono audio in on Denon AVR-1707 this should work absolutely fine as long as your using an analogue input on the tv if HDMI you would need to purchase a Digitial to analogue audio converter. Hope this helps
Jan 31, 2011 | Denon AVR-1707 Receiver
Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Nov 03, 2009 | Denon AVR-2308CI
Dec 29, 2008 | Denon AVR-3805 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
Denon AVR-2105
May 26, 2008 | Denon AVR-2105 Receiver
How do I hook up my 2 outdoor speakers to a Denon 3805.....P.S no remote
PUT YOUR OUTDOOR SPEAKERS INTO SURROUND BACK SPEAKER "PORTS"AS YOU CALL THEM GEMMEG THEN GO TO UR SET UP MENU AND SWITCH ON ZONE 2 OR IT MAY BE AS SIMPLE AS A SWITCH ON THE FRONT OF YOUR AMP.IFF YOU STILL HAVE NO SOUND YOU MAY HAVE 2 TURN THE VOLUME UP FOR ZONE 2.ALSO SOME AMP NEED TO HAVE THE SOURCE ; IE WHAT U WANT 2 PLAY INTO ZONE 2 FOR EXAMPLE YOUR CD PLAYER.HOPE THIS HELPS ,IFF NOT GET BACK 2 ME 2 C IFF I CAN DO ANYTHING ELSE.
May 20, 2008 | Denon AVR-3805 Receiver
Denon AVR-1707 Receiver Logo
168 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
