Question about Bose Cinemate Digital Home Theater System Speaker
Bose cinemate acoustimass module
The small speakers work fine, but the acoustimass module has a low faint rumbling, can hardly decern music or vocal hardly audible When I turn the volume up high I can feel air moving out the speaker port,but you can hardly make out what is playing,just that low rumble sound only louder
  • 1 more comment
  • Daner Jan 21, 2008
    Nothing loose inside.. Could the speaker be Blown or would it be electronic. its the large woofer.
  • Gross144 Feb 04, 2008
    I'm having the same issue, from my DVD player the woofer is fine, but from the cable it doesn't do anything. Any body know how to fix that?
  • Dragons1118 Feb 09, 2008
    I havent been able to get anything from the acoustimass module. The other two speakers work fine. I have verified it with a THX speaker test. I hear the tone for all other positions, but the bass doesn't come through at all.
  • 70 Answers
Try taking ones apart that have the rumbling and see if theres anything loose inside
Posted on Jan 21, 2008
Could you repair a acoustimass module(cinemate gs series2)BOSE
sadly we here at fixya can only give advise . we are not a repair facility
Aug 08, 2016 | Audio Players & Recorders
Replacement part for Bose Cinemate Interface
Replacement parts for Bose Cinemate Interface can be foudn at amazon, take a look here: Amazon com Bose Cinemate parts. I hope this helped. Cheers
Oct 29, 2011 | Bose Cinemate Digital Home Theater System...
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
Can the bass and treble be adjusted on the bose cinamate?
There is a bass adjustment knob on the acoustimass module(subwoffer). That is the only adjustment I am aware of at this time.
Nov 25, 2010 | Bose Cinemate Digital Home Theater System...
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Replacement speaker (upper) for Bose double Cube.
try a music specialty store or radio shack if you want to only replace the small speakers inside the cubes. If you want to replace the whole cube, there are others out there. Look on ebay and or amazon I think the brand is JA Audio. A knock off of the bose cubes that can be used as stand alone speakers without the module.
Jan 05, 2009 | Bose Acoustimass 15 System
Changing the inpout voltage of inside bose Acoustimass module
Probably not, but you can install a step-down transformer if there's room inside the unit. Since these speakers don't use much current, a small transformer will work. It doesn't have to be a 220-to-110 transformer either - any transformer designed to cut the voltage in half is fine. A 24 volt-to-12 volt transformer will also work.
Aug 13, 2008 | Bose Acoustimass 15 System
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Connecting Bose Acoustimas Wofer to a Sony receiver
you cannot hook a bose system up with any other system not even another bose
Jul 01, 2008 | Bose Cinemate Digital Home Theater System...
Bass module
You dont have to crank up the volume to hear the bass man. It sounds like you have a bad connection some where. check all your connections and also if the wires are shinning and not dull at the connection point. having carbon or dust there will not help.
Apr 10, 2008 | Bose Acoustimass 15 System
Bose Cinemate Digital Home Theater System Speaker Logo
547 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
