Question about Pioneer DEH-P8500MP CD Player
Unit opens and closes on its own
This just started a week ago: I start the car, and the unit opens and closes on its own and the only way I can get it to work is to make sure there's a cd inserted and I hold the switch button down to 'trick' the system. Then I can choose to play the cd or the radio. Any help? Sure do appreciate it.
  • Anonymous Feb 08, 2008
    I am having the same problem; I do however have a half the
    solution. If you were to reset the radio (pressing the small button with a
    paper clip on the front panel) that will stop that opening and closing of the
    panel. However, that will reset all the radio stations, which you can program
    them back, but you will not be able to set the Audio settings. As soon as you
    hit the open button to open the front panel to set the audio setting, the panel
    will open half a way and then close again and go back to the loop of opening
    and closing. Hope this helps you for the time being until someone can come out
    with a full fix.
I think I got the second half of the solution for this problem. Please look at post "Unit powers down when motorized face opens" for a solution. Seems like we need to buy the ribbon that connects to the face plate to fix this problem.
Posted on Feb 08, 2008
6ya staff
SOURCE:
Lg lp0910wnr fl code this started less than a week ago...The portable AC unit turned off & FL started blinking...so I read up on it & drained it in the tub hooked it back up & turned it on & it worked...
Hi humidity levels is the problem. Once the atmosphere dries out a little at your location, expect the frequency of the draining operation to lessen. Your AC unit is working great. there is no problem with it.
Aug 06, 2018 | Heating & Cooling
A/c putting out cold air. on passenger side warm air on driver side. Had it recharged 2 weeks ago. What would cause this problem?
Check the heater motor actuator, in the inside in about the center under the dash attached to the heater duct. The actuator is a small motor that opens and closes the door on the air unit to direct the hot or cold air. One of the doors is not closing from the heat side of the unit.
Oct 11, 2015 | 2005 Chevrolet Malibu Maxx
The unit squeaks whenever turned on, no matter what level the fan is blowing (Lo, Med, or Hi). Started about a week and a half ago.
A rhythmic squeak sounds like either a fan motor bearing going bad or just vibration from the unit running thats wiggling something loose inside the unit.
Jul 23, 2015 | Everstar Portable Air Conditioner Everstar
I have a Candy GOU218 when I push the start button it does start the dryer but as soon as I release my finger from the button it stops, It started doing it around a week ago so I had to push and hold
There are push to start circuits used for motors and then there are holding circuits that keep the unit running. This way the dryer stops if the circuit is open due to high temperature or end of the cycle. It seems as if the holding circuit (could be a rotary switch that stays closed while the dryer is running) or a holding circuit relay (stays closed until circuit is broken by the control) has failed.
Jan 09, 2014 | Candy Dryers
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Wireless keypad will close door but open
WHEN YOU CHANGE THE BATTERY YOU NEED TO REPROGRAM THE UNIT.
IF THAT DOESN'T WORK YOU PROBABLY HAVE A BAD KEYPAD.
HOPE THIS HELPS
Apr 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
When antenna is open screen starts flipping out of control
TRY USING AN EXTERNAL ANTENNA. THIS SOLVED MY SIMILAR PROBLEM.
LENN
Mar 20, 2009 | Garmin iQue 3600 GPS Receiver
Drivers Door Window/Locks aren't working
driver side lock and window switch... if its all one unit... i had a 95 cherokee laredo that did that... changed the switch and it fixed my problem...
Mar 15, 2009 | 2003 Jeep Grand Cherokee
Door won't open or close
It may be stuck on the stop bolt... Is the carrier ( the part that moves the garage door) jammed?
Feb 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pioneer DEH-P8500MP CD Player Logo
171 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
