Question about Nokia 6101 Cellular Phone
No power good battery but no power
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 111 Answers
Have your phone flash programmed
Posted on Jan 28, 2008
Why will the camera power on when plugged in, but will not power on when useing batteries?, the batteries are new
Batteries are new but are you sure that they are good? Did you test them for voltage and amperage? Weak batteries will often not work in older digital cameras because they needs lots of power from good, strong battery.
Aug 31, 2015 | Polaroid PhotoMax PDC 640 Digital Camera
Disconnected battery while on a long trip.came back, charged the battery and reconnected battery. Now I have no elec power anywhere .i checked fuses they looked good. Someone told me I might have activated...
disconnecting the battery corrupts the CPU program as there is no power to maintain a memory. Use a code reader to reset the CPU and see what problems remain
Feb 18, 2014 | 1997 Cadillac Seville
Pronto M51 Wheelchair doesn't have as much power as it used to. Batteries are good.
Have you had the batteries load tested? How do you know the batteries are good?
Apr 21, 2013 | Invacare Pronto M51 Power Wheelchair
The battery quickly charge and discharge. And when the battery discharge and I connect the power adaptor to 220 volts power source, the laptop automatically shutdown and could not open unless the battery...
Do you live in Europe> Typically power supply should only be 110 - 115V
Battery is simply no good any longer. If you can get 2 yrs from a battery you're doing good.
Try removing the battery and using the power supply and charging battery when not in use. Replace battery.
Hope this helps
Jan 07, 2011 | Computers & Internet
Can I back feed through my inverter from a generator to charge my batteries?
What does it invert?Higher voltage to lower or what?Either way,with 1200 watts being inverted,it is not a good idea to charge a battery with that kind of power.Batteries need to be charged low and slow.We are talking milliamps for hours.Fast charging a battery results in a very good chance of explosion,which is never good.Acid from the battery will go everywhere.
Aug 04, 2010 | Coleman Cable Power Inverter PMP1200
Battery-charging-power issue,
wrong power pack, ask at HP.com yet the real HP forum
it not the pack then the power regulator chips are blown on the mobo.
a vary bad deal that.
the OS is not bad, the power runs even in BIOS and no HDD.
the mOBO is what chargers the battery.
there can be 2 chips one for main reg, and one of charge reg.
the PC sees you plug in the power pack and see power from the A/c side go good, if not it goes to battery
the chip does all That magic, not WINDOWS.
what if the new battery was bad. (lots are, ever see the huge recall on batteries?????????) for GOOD REASON.
I keep 2 good batteries from mine all the time., 2.
There is no way to diagnose any charger chip with only 1 battery
needs 2 good batteries to get hard evidence proof.
If you look at you mobo and see those 2 chips there.
mine is 8mm square, and is SMD chips
you'd play hell testing that. no? the pins are underneath it.
of the AC pack is correct, for Volts and watts
then the mobo is bad,
the switch over to Battery at AC power on,
means the AC side is bad or weak,
or the battery has shorted cell, did you measure your battery first with a voltmeter to see if one cell is shorted, as they ALL LOVE TO DO>?
Apr 10, 2017 | Compaq Presario C552US Notebook PC
Lost all power. locks windows radio key ****. battery good.
Sounds like a master fuse, or a fusible link.
Using a volt meter with one end grounded, start at the positive post of the battery. Touch the probe there. Good power? try the clamp. Good power, try the other end of the positive battery cable.
Keep moving down the wiring away from the battery until there is not good power. Whatever device or connection you moved past when you no longer found good power is the culprit.
Jul 06, 2010 | 2004 Buick Rainier
No power from battery or power cable
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Dec 28, 2009 | Dell Latitude D510 Notebook
Cannot turn on my LG Notebook anymore
Will the laptop boot with the power adapter connected and battery removed? If so, boot it up and install the battery once it's booted up. If okay now, the battery was just really really drained. If okay with no battery but no good with battery, the battery may be bad, or something in the charging circuit may be defective - keep the battery out or replace mainboard ($$$$ - get a new laptop)
If no good with ac adapter and no battery, test the adapter with an electrical meter. It should be putting out 18-19 volts. If not, try a replacement adapter. If adapter tests good but laptop won't boot with no battery, likely the mainboard.
Also - remove hard drive and try to power up. If good, replace hard drive. If no good, reinstall hard drive and remove ram and try to power up. If it powers up, clean the ram and slot contacts gently with a pink pencil eraser and try testing each ram chip in each slot, 1 chip at a time. If still no good, start shopping for a new laptop.
Let me know if this helps or not...
Aug 08, 2009 | Computers & Internet
Ford 2002zx2 will not start tried jumping;nothing not even headlights. battery is good
If nothing electrical works, even though the battery is good, it has to be a main power cable.
The main positive power cable runs first to the starter usually, and then to the fuse block.
The negative cable usually goes to the body and the engine block.
Jul 25, 2009 | 2002 Ford ZX2
Nokia 6101 Cellular Phone Logo
24 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
