Question about Uniden CXA15198 Twin Corded/Cordless Phone
Please help...cordless phone not turning on?
The cordless phone has completely stopped working...it will not even turn on...when it sits on the charger the light comes on, so I know it's connecting...but when I hit the TALK button to turn it on, nothing happens...no dial tone...nothing.
Do you have any suggestions?
  • GPinson Nov 23, 2008
    I have the same problem. I even replaced the battery, but still the same symptons.
  • 86 Answers
Sounds like the battery is dead. The base is recognizing the phone, just not able to charge the bad battery.
Posted on Jan 21, 2008
My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
Feb 01, 2011 | Panasonic KX-TG5576 5.8 GHz Cordless Phone
My Sony SPP-930 cordless phone is about 15 years old. Just recently it stopped working. The base lights work fine but when I lift the handset off the base and press TALK, all I get is 4 beeps. I bought a...
The problem is in the main base, the cordless phone is unable to communicate with the base because it has stopped working that is why you are getting the four beeps. It is more cost effective to replace the complete phone system than repair. The only other possibility "and it is long short" unplug the power and the phone line cord from the wall and let it sit at least 30 minutes, this might reset the processor ic and get your system working again.
Jan 07, 2011 | Sony SPP-930 900 MHz Analog Cordless Phone
I need a manual for CWD4901SE, also how does it turn on ??
I've discovered that a bad battery will stop my handet turning on at all, even when it's sitting on the base station and apparently charging - which isn't too illogcal, really.
With a charged battery, simply putting it back on the base station then picking it up turns it on.
Oh - and I also need a manual.
Best wishes,
Robbie
Oct 05, 2010 | Cable_and_wireless CWD4901 Cordless...
My mother-in-law has a uniden phone (with four cordless) and all 4 of the phones show low battery even though the have been sitting in their bases charging. Any thoughts? Thanks in advance
are the charging bases plugged in and turned on? If they are..try replacing batteries on one and see if it works....if so replace all batteries
Jun 15, 2010 | Uniden Cordless Phone
I have an OT7500 cordless which shows on screen the word (searching) even on base port,There is no conection in or out but it still rings & records messages,Can you help please,thanks Alan.
Can you please turn off your phone and then remove the battery. After that, place back the battery and turn on your phone again. Please make a comment if problem persist.
Dec 15, 2009 | Cable_and_wireless CWD4901 Cordless...
Continuous Flash of Visual Ringer(Uniden DECT 6.0 Cordless)
UNIDEN MODEL EZX290 HANDSET>>>VISUAL RINGET AT TOP (YELLOW LED) FLASHES. HOW DO I TURN THT OFF?
Jun 28, 2009 | Uniden DECT 6.0 Cordless Phone ID
My phone is dead
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
I turned the ringer off on my phone and now theres no dial tone.
Unplug the phone entirely for about 5 minutes and then plug it back in and see if this works.Good Luck!
Apr 15, 2009 | Vtech IA5854 5.8 GHz Cordless Phone
Can use the phone it is only reading searching on the display.
Question:
Answer:
Apr 07, 2009 | Uniden DECT 6.0 Cordless Phone ID
The battery won't charge. Its been sitting on the charger for two days now & nothing is charging. I checked the wires but nothing seems to be wrong. Nothing even shows up on the screen. No words, no...
Can you swap a battery from one that's working? That will tell you if it's the phone or the battery. If it's the battery then you should be able to replace that.
Good luck and if this solution was helpful please rate it.
Mar 30, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Uniden CXA15198 Twin Corded/Cordless Phone Logo
281 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
